Author Topic: Passenger door  (Read 3906 times)
Offline Cheyenne1010
Passenger door
« on: January 20, 2018, 05:03:07 am »
I have a 1973 chevy C10,when I open the passenger door everything is fine,but when I go to close the door about half way the door stops and as im pushing the door close it makes a knocking sound then the door close's without any problem.anybody have any idea what my door is doing and how to fix it?
Thank you guy's for your time.
Re: Passenger door
« Reply #1 on: January 20, 2018, 07:30:55 am »
Look at the door check spring and hinges including pins and bushings.
Offline 75gmck25
Re: Passenger door
« Reply #2 on: January 20, 2018, 07:49:46 am »
Spray some lithium grease on the door check rollers and spring (really a bent piece of round metal).  The spring needs to slide and the rollers must roll freely.  Otherwise you hear a lot of popping as it moves.
Bruce
Re: Passenger door
« Reply #3 on: January 21, 2018, 06:56:05 am »
I sprayed the hinges and those rollers and still getn that popping sound.I guess the only thing to do is replace the pins and wheels.
Re: Passenger door
« Reply #4 on: January 21, 2018, 08:07:15 am »
You can replace the hinges altogether.
