Author Topic: detent?  (Read 6329 times)
Offline markzepp820
detent?
« on: March 07, 2006, 02:54:00 am »
from what i hear, the th400 uses a detent solenoid to control the kickdown. Its a wire that leads from the tranny to the gas pedal with a 12 volt current. Does the detent just control kickdown passing gear only, or do the modualtor and detent work together?
Offline ChevyGuy
th400
« Reply #1 on: March 07, 2006, 12:36:00 pm »
The vacuum modulator is for shifting and the kickdown is ran by the solenoid.
Offline markzepp820
detent
« Reply #2 on: March 07, 2006, 06:59:00 pm »
thought so, thank you
Offline DnStClr
Re: detent
« Reply #3 on: March 11, 2006, 10:30:00 am »
But that's still a good question- I would think they have to work together for proper passing gear.
 BTW, one way you can check for a bad modulator is to remove the vac line and turn it (modulator) to see if any tranny fluid comes out. If it does, the modulator has a bad diaphram.
Don
87 Chevy Silverado
Offline markzepp820
detent
« Reply #4 on: March 11, 2006, 07:30:00 pm »
Thank you DnStClr.
