Author Topic: Transmission filter spacer  (Read 3830 times)
Offline Jon87V20
« on: January 20, 2018, 11:52:39 pm »
I changed out my transmission filter today and after I finished buttoning the whole thing up, I noticed that cylindrical spacer that goes between the filter and valve body sitting on the ground next to the old filter. Then I had set it on the bumper while I was cleaning up and it disappeared... doh.
I'm wondering what it's function is, and can I get away with leaving it out. I realize GM put it in there for reason. Just wondering if it's essential to normal operation. I'm not trying to lazy about it, it just sucks because I had to do that out in the cold and rain today and don't really want to do it again right now.
Thanks, guys.
EDIT: This is a '87 Suburban V20 with TH400 with deep pan.
« Last Edit: January 21, 2018, 12:03:09 am by Jon87V20 »
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: Transmission filter spacer
« Reply #1 on: January 21, 2018, 08:11:16 am »
You need to put it back in. The filter will drop from the pickup tube without it.
Offline Jon87V20
« Reply #2 on: January 21, 2018, 10:20:17 am »
Ok. Darn. If I can’t find it out there in the driveway, can I use washers to take up the 4 inches needed there?
« Last Edit: January 21, 2018, 02:55:44 pm by Jon87V20 »
« Reply #3 on: January 21, 2018, 05:27:38 pm »
4" ? The long spacer is about an inch for deep pans. Whatchoo talkin bout Willis? Just cut a piece of steel line an inch long and you'll be fine.
