Author Topic: 87 Chevy slips out of 4x4  (Read 22548 times)
Offline dc7432
« on: February 07, 2018, 08:07:19 pm »
I have a 87 Chevy 4x4 and it pops out of 4x4 I have to hold the shifter to keep it I 4x4. I adjusted the nuts on the lineage from under the cab should I adjust more or is it an internal adjustment Thanks
Re: 87 Chevy slips out of 4x4
« Reply #1 on: February 09, 2018, 09:06:33 am »
we have to know more about your truck. like what trans and transfer case it has. if its original it should be a 700r4, th400 or sm465 and transfer case could be a 205 or 208
Offline dc7432
« Reply #2 on: February 10, 2018, 11:56:00 am »
It's original T400 w/ 208, thanks again
Offline dc7432
« Reply #3 on: October 14, 2018, 03:52:34 pm »
Still have the problem. Does it sounds like an internal problem? I did tighten up the linkage but it didn't fix the slipping, thanks.
« Reply #4 on: October 14, 2018, 06:22:18 pm »
First thing to do is check the mounts, crossmember and linkage. After that check the linkage adjustment. If it's still popping out, replace the unit. You can pick up a 208 dirt cheap still which is less than a rebuild.
Offline dc7432
« Reply #5 on: October 15, 2018, 04:46:48 pm »
I check and everything is fine. Are 208s the same for v10, v20 and v30 in the same year. Spline count the same. Thanks
« Reply #6 on: October 15, 2018, 06:12:59 pm »
the 208s are really going to depend on what trans theyre behind. 700r4 will have a 27 spline input shaft while a th400 will have a 32 as well as a sm465
