Body, Glass & Paint
Cab and doors
Topic: Cab and doors (Read 5022 times)
Smitty31
1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
Cab and doors
February 12, 2018, 02:13:25 pm »
Is the cab and doors the same on a 1979 and a 1986 c10 pickup. I think they are just wanted to confirm it.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
zieg85
Re: Cab and doors
February 12, 2018, 03:23:07 pm »
Doors yes and no, cabs no... Door shells same, glass thickness lightens up after 1981. Cab differs where the hood hinges mount and the wiper switch goes to the steering column. All can be dealt with if you have the skills.
Smitty31
Re: Cab and doors
February 12, 2018, 04:56:19 pm »
I guess what I'm asking will a 1979 door for a 1986 cab.
zieg85
Re: Cab and doors
February 12, 2018, 05:06:51 pm »
Quote from: Smitty31 on February 12, 2018, 04:56:19 pm
yes door will go on it no problem. Door pad and all from the 86 will go on it.
Re: Cab and doors
February 13, 2018, 03:37:14 pm »
the inside handles and vent handles will be different. not sure if you can swap them out, but you might be able to make it work
Last Edit: February 13, 2018, 03:39:37 pm by Irish_Alley
Re: Cab and doors
February 13, 2018, 03:39:02 pm »
77-80
81-87
Body, Glass & Paint
Cab and doors
