Author Topic: Cab and doors  (Read 5030 times)
Offline Smitty31
  • 1979 GMC High Siera 4wd & 1986 custom deluxe 2wd
Cab and doors
« on: February 12, 2018, 02:13:25 pm »
Is the cab and doors the same on a 1979 and a 1986 c10 pickup. I think they are just wanted to confirm it.
IF ITS WORTH DOING. THEN ITS WORTH DOING RIGHT.
Re: Cab and doors
« Reply #1 on: February 12, 2018, 03:23:07 pm »
Doors yes and no, cabs no...  Door shells same, glass thickness lightens up after 1981.  Cab differs where the hood hinges mount and the wiper switch goes to the steering column.  All can be dealt with if you have the skills.
Offline Smitty31
Re: Cab and doors
« Reply #2 on: February 12, 2018, 04:56:19 pm »
I guess what I'm asking will a 1979 door for a 1986 cab.
Re: Cab and doors
« Reply #3 on: February 12, 2018, 05:06:51 pm »
yes door will go on it no problem.  Door pad and all from the 86 will go on it.
Re: Cab and doors
« Reply #4 on: February 13, 2018, 03:37:14 pm »
the inside handles and vent handles will be different. not sure if you can swap them out, but you might be able to make it work
« Last Edit: February 13, 2018, 03:39:37 pm by Irish_Alley »
Re: Cab and doors
« Reply #5 on: February 13, 2018, 03:39:02 pm »
77-80
81-87
