Author Topic: Broken tab for hood release  (Read 3549 times)
Offline claude
« on: February 14, 2018, 09:02:10 am »
1985 K20. One of the 3 tabs that holds the spring under the front of the hood that makes contact with the core support broke off. The spring will not stay in place which makes opening the hood a 2 person job. One person pulling up on the hood while the other person pulls and releases the hood release lever in the cab. Just got body work done and painted the pickup and do not want to replace hood. Is there a way to keep that spring in place?
1985 K20, manual T, 373 gears, 208 transfer case
Rebuilt roller 355 engine, Comp XE264XR cam 212/218 @ .050, .487/.495 lift w/1.5 RR, LSA 110, Dart Iron Eagle Heads with 2.02/1.6 SS valves. 325 HP at 4000 RPM. 335 HP @ 4900.
421 ft*lbs torque at 4000RPM
Offline impco lpg
Re: Broken tab for hood release
« Reply #1 on: February 14, 2018, 01:31:44 pm »
large penny washer bigger than spring, and self tapper.
« Last Edit: February 14, 2018, 02:40:14 pm by impco lpg »
1983 cucv m1009  blazer 6.2 4x4
1991 1500 suburban 5.7 4x4 lpg
2003 dodge ram 5.7 4x4 lpg
1985 chevy c10 stepside  2wd 5.7ltr 350 lpg
« Reply #2 on: February 14, 2018, 05:27:32 pm »
Weld in a new tab if you want it to look correct, screw in a strap or a washer if you don't have a welder, tack the spring in place if you have a welder and don't really care. There's a lot of ways to fix it without replacing the hood.
Offline claude
« Reply #3 on: February 15, 2018, 12:49:28 pm »
Thanks impco lpg  and vileZambonie for suggestions. I have a good friend who is a good welder & fabricator & will have him look at it when he gets back from wintering in Arizona. Again, thank you.
