Author Topic: Vibration rear at 45mph  (Read 6686 times)
Offline AmericaMade
« on: February 14, 2018, 10:39:06 am »
Could a vibration on the rear/drive line be a bad u-joint?
What does one look for in a bad u-joint?
After the mechanic gave this note, I took to going this speed and faster and did not notice a vibration at or above 45mph. The truck is a bit bumpy as the struts are done with which Im replacing anyway.. also rear leaf spring bushings are also needing replacement.
83’ C10 Scottsdale
1983 C10 Scottsdale 383 Stroker TH/350 Holley 850 Double pumper carb
Re: Vibration rear at 45mph
« Reply #1 on: February 14, 2018, 05:43:13 pm »
You don't have struts, you have shock absorbers. If the vibration is speed dependent then shocks and spring bushings are most likely not where you should be looking. If there is noticeable play in the u-joint, replace it. If the u-joints are getting really hot or just look old, replace them.  That being said, speed related vibration can be many things. Does it matter if you are accelerating or decelerating or in neutral?
Offline KJD
« Reply #2 on: February 14, 2018, 07:01:50 pm »
If you have a two-piece drive-line you'll want to check your carrier bearing also.
« Reply #3 on: February 16, 2018, 04:10:36 pm »
like vile said we need to know more about it. what speeds and what conditions it does it at, do you feel it in the whole truck or just the steering wheel???
Offline AmericaMade
« Reply #4 on: February 22, 2018, 10:55:22 am »
That is my issue I dont notice anything. When I took it in, to get a once over the mechanic said there wasvibration above 45mph. Finally I have it driving again, I dont notice anything but what I gather it could the u-joint. I manually shook that area and didnt notice any play.
« Reply #5 on: February 23, 2018, 07:27:22 am »
so the only reason you noticed the vibration is because of a mechanic said so? imo even if you only noticed after he said anything would be a placebo type of effect. but if you still havent felt anything i wouldnt think much about it and depending on the mechanics suggestions i would probably even start using another shop.
Offline AmericaMade
« Reply #6 on: February 23, 2018, 08:37:22 am »
I’ve tried to “feel the vibration” but i havent been able to. I was just wondering what it could possibly be. What could create a vibration at that speed. Ive gathered the u- joint could be culprit. when I shook, the u-joint to see if its lose. It was solid.
Online bd
« Reply #7 on: February 23, 2018, 11:09:56 am »
If YOU don't feel a vibration then there is no vibration to feel.  You can expend a lot of energy chasing a "problem" that doesn't exist.
« Reply #8 on: February 23, 2018, 01:25:34 pm »
like bd said you could be chasing something that doesnt exist. and it could be a u-joint, driveshaft, a tire, a wheel or all the above or even something in the engine or trans.
Offline Jon87V20
« Reply #9 on: February 23, 2018, 01:35:21 pm »
Did the mehanic make any suggestions that involved significant costs? Sounds kinda shady, man.
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
