Author Topic: Ignition Issues...  (Read 4701 times)
Offline Mason86
Ignition Issues...
« on: February 16, 2018, 05:33:30 pm »
I recently did intake manifold gaskets on my 5.7 sbc
After getting everything back together, it won’t run. It turns over fine, but I have no spark. I started tracing things back, and I have power at the ignition coil but not the spark terminals on the cap. I replaced the distributor along with the coil, cap, module, everything. I’m pretty stumped, if you have any input I would really appreciate it.
Re: Ignition Issues...
« Reply #1 on: February 16, 2018, 05:42:20 pm »
Welcome to the site.
Please include Year, Make, Model etc.. when posting
This keeps us from having to guess and make assumptions, so that you receive relevant responses.
Offline Mason86
« Reply #2 on: February 16, 2018, 06:05:35 pm »
1986 Chevy c10
Swapped from a 305 to 350 sbc
Offline Mason86
« Reply #3 on: February 16, 2018, 06:25:06 pm »
The module is getting around 6 volts and the coil is getting 12. Where is it going???
« Reply #4 on: February 16, 2018, 07:03:13 pm »
HEI needs 12 volts at the ignition coil terminal on the cap. Where are you measuring 6 volts?
Offline Rapid Roy
  • Euless, Texas
« Reply #5 on: February 16, 2018, 08:04:35 pm »
Welcome
Mopar by Birth
Chevy by Choice
Offline Mason86
« Reply #6 on: February 16, 2018, 09:14:33 pm »
Measuring 6 volts at the connector that goes to the ignition module. I am getting 12 to the coil though
