Author Topic: Lowering a 1982 shortbed stepside  (Read 8285 times)
Offline truckguy
« on: February 17, 2018, 12:34:27 pm »
I want to lower the truck with a 4/6 drop. The front will be spindles and springs (with a HD 1.25" rotor upgrade). In reading about dropping the rear, it seems I'll need an axle flip to get the six inches. I'm not going to use the c-notch kits because I've read posts that show that they weaken the frame significantly and I want to be able to continue to use the truck for hauling and towing. I am OK with a notch as long as it cuts less than half the width of the frame rail. The finite element analysis (FEA) of frame strength after a notch shows that the overall height of the frame is what gives the strength. I haven't seen anyone discussing the mono leaf spring option. They seem like a good choice except for the cost.(https://www.brotherstrucks.com/73-87-REAR-MONO-LEAF-SPRING-SET-REVERSE-EYE-6/productinfo/MLSR087/).  Has anyone used a reverse eye mono leaf spring to lower the rear? And if so, what about frame clearance?
Offline Rapid Roy
  • Euless, Texas
Re: Lowering a 1982 shortbed stepside
« Reply #1 on: February 17, 2018, 01:57:09 pm »
Welcome to the site
Mopar by Birth
Chevy by Choice
« Reply #2 on: February 17, 2018, 02:58:51 pm »
welcome from maryland
Offline truckguy
« Reply #3 on: February 17, 2018, 10:36:55 pm »
Thanks!
« Reply #4 on: February 17, 2018, 10:50:03 pm »
lol sorry i couldnt help you with your question. but how much do you plan on hauling and what type of trailer?
« Reply #5 on: February 18, 2018, 08:02:12 am »
You can just leave the main leaf and the second leaf in your spring pack with a lowering shackle and see if it sits where you want it.
