Author Topic: 2 piece timing cover  (Read 3518 times)
Offline buick
« on: March 14, 2018, 08:55:33 pm »
does the 2 piece timing cover work good when doing a timing chain so you dont have to mess with the oil pan bolts and gasket?thanks
Offline Rapid Roy
  • Euless, Texas
Re: 2 piece timing cover
« Reply #1 on: March 14, 2018, 09:04:58 pm »
Welcome
Mopar by Birth
Chevy by Choice
« Reply #2 on: March 15, 2018, 03:07:10 pm »
They are beneficial for cam swaps and roller cam thrust bushing service. Not designed to make replacing a chain and gears any different.
Offline FlatBlack77
« Reply #3 on: March 15, 2018, 07:58:05 pm »
You will need to remove the oil pan to install it properly anyway. So remove it all at once, replace the chain and sprockets, then replace the cover and pan gaskets
