Author Topic: Sliding rear window  (Read 6357 times)
Offline RBolig
Sliding rear window
« on: April 05, 2018, 01:46:50 pm »
Guys, I need some help. I am removing the solid rear window in my '79 Cheyenne and replacing with a slider (I believe it is aftermarket). I bought a new gasket, and the window assembly does not fit the Precision seal. Is there a special gasket for these windows that are not GM original?
The image shows the seal being too large.
Re: Sliding rear window
« Reply #1 on: April 05, 2018, 02:15:45 pm »
They fit a little squirrely until they are installed. There are two different gaskets available, one with a zipper and one without.
Offline RBolig
« Reply #2 on: April 05, 2018, 02:25:49 pm »
I got the one with "the zipper", but the gasket looks too large. I am thinking it should fit snug to the window frame at least. Am I wrong?
« Reply #3 on: April 05, 2018, 02:49:00 pm »
That style gasket goes on the cab first, then you put the window in, then zip it up tight
Offline RBolig
« Reply #4 on: April 05, 2018, 03:57:18 pm »
Zieg, Sounds like a plan. I'll give that a try.
Offline RBolig
« Reply #5 on: April 07, 2018, 08:32:52 am »
Zieg85, you were correct, window is now installed. Thanks.
Now, about those pesky chrome corner pieces..... Had to walk away for a while.
Offline philo_beddoe
  • 77 C-10
