Author Topic: Axle upside down?  (Read 6589 times)
Offline ken4444
Axle upside down?
« on: April 20, 2018, 10:05:16 pm »
My C10 has a spring-under conversion. I happened to notice the casting numbers on the differential housing are upside down.  What's the likely story here?  Is this legit, a total hack, or something in between?  I'm thinking it doesn't matter from a mechanical perspective, but my experience here is minimal.
Re: Axle upside down?
« Reply #1 on: April 21, 2018, 06:20:17 am »
It's flipped, meaning over the spring, not upside down. If the vent hose was pointing toward Earth and in fact upside down, you'd be going backwards when you go forward.
Offline ken4444
« Reply #2 on: April 22, 2018, 09:10:01 pm »
Good point on the vent hose.  That is in the right place.  Is it common to see the casting numbers upside down on GM or other axles?
« Reply #3 on: April 23, 2018, 05:13:22 pm »
Depends on whether you're standing on your feet or on your head.
Offline ken4444
« Reply #4 on: May 18, 2018, 05:22:18 pm »
Another question: Are the axle shock mounts OEM?
« Reply #5 on: May 18, 2018, 05:59:51 pm »
no they are aftermarket. Probably came with the flip kit
Offline ken4444
« Reply #6 on: May 18, 2018, 07:01:22 pm »
So this begs the question...  if I move the axle back under the springs, what modifications will be required?
« Reply #7 on: May 19, 2018, 06:21:14 am »
Shocks with the correct length/travel. Most likely 2" longer.
Offline ken4444
« Reply #8 on: May 19, 2018, 08:28:59 am »
I'm also thinking that the pinion angle will require some consideration as well.
« Reply #9 on: May 19, 2018, 08:30:44 am »
shouldnt if he utilizes the stock spring pads
« Reply #10 on: May 19, 2018, 11:03:50 am »
shouldn't what?
Yes you should always check the pinion angle after suspension or driveline mods
« Reply #11 on: May 19, 2018, 11:44:51 am »
if he uses the stock axle perches that are still on the axle, the pinion angle should be back at the stock location
