Author Topic: Steering Box Leak  (Read 5375 times)
Offline Ronno6
  • Elder Student
Steering Box Leak
« on: April 25, 2018, 07:38:00 pm »
Next on the hit parade, the steering box on my 1984 C19 is leaking oil.............
Is this common??
You can lead a man to water, but yoiu can't keep him from pissing in it.
Re: Steering Box Leak
« Reply #1 on: April 25, 2018, 07:57:38 pm »
leaking oil is very rare. power steering fluid or tans fluid is somewhat common but typically an easy fix but you just have to find out where its leaking, it could be a hose or a seal on the gear box or even on the pump
Offline Ronno6
  • Elder Student
« Reply #2 on: April 25, 2018, 08:22:48 pm »
It is not ps fluid. It is amber in color.
I believe it is leaking out of the seal around the input shaft, as I had removed the column recently.
the engine has not run since I backed it into the shop 2 weeks ago, and this puddle is recent.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #3 on: April 25, 2018, 09:07:39 pm »
Power steering is amber, also Brake fluid.
If you believe it is the steering box leaking, then it is power steering fluid. However make sure to check brake fluid level just in case.
 1986 Chevy K30(under repair)
Offline Captain Swampy
  • Wisconsin
« Reply #4 on: April 26, 2018, 10:10:36 pm »
It's possible someone put hydralic oil in it also. You could maybe try a new seal, but probably will end up with a reman. Dump the old oil out and I prefer to use ATF in these trucks.
Offline Ronno6
  • Elder Student
« Reply #5 on: April 27, 2018, 05:14:29 pm »
I guess it is ps fluid.
But, it is leaking from the steering box at the input shaft seal.
