Author Topic: Dies at a stop..  (Read 5980 times)
Offline scritt83
Dies at a stop..
« on: April 30, 2018, 03:57:16 pm »
86...gmc...4x4...305
Pickup wants to die when sitting at a stop... Like longer than a minute of idling in gear... Usually starts doing it when  it's time to go then it's like it's starving for gas... Have to pump the pedal attempting to keep it running... After I get going then its
's back to normal...
Could it be pick up coil? Thought if it was it may do it more than just at a stop...
I did recently put on a electric fuel pump to eliminate the mechanical one on previous issue I had... Think I might swap it back and go from there...But you would think it would deliver fuel at idle if it does while driving though...
Re: Dies at a stop..
« Reply #1 on: April 30, 2018, 06:02:22 pm »
How did you install the pump? The mechanical pump works fine for carburetors.
Offline scritt83
« Reply #2 on: April 30, 2018, 07:15:36 pm »
I was having idling issues at the time and a friend had a electric one so installed it to rule mine out...installed it where the mechanical one was...filter before and filter up by carb
Sent from my SM-G920V using Tapatalk
« Reply #3 on: April 30, 2018, 07:40:16 pm »
Most electric pumps need to be close to or even inside the tank. I would reconnect the mechanical and change the fuel filter. As far as the stalling issue:
check carburetor, check for vacuum leaks, check for tune up, check ignition timing.
« Reply #4 on: May 02, 2018, 07:55:44 am »
to add to this, high idle could be a vacuum leak and stalling like you talk about could also be a vacuum leak or poor tune.
Ignition Timing for First-Generation GM V-8 Engines
but i would do it in the order vile suggested
Offline scritt83
« Reply #5 on: May 02, 2018, 09:16:48 am »
Just changed back to mechanical pump... Seems like that was the issue... I believe it was running out of gas like the pump wasn't keeping up...
« Reply #6 on: May 02, 2018, 09:55:32 am »
so then what caused the original issue?
Offline scritt83
« Reply #7 on: May 02, 2018, 10:05:51 am »
Carburetor
