Author Topic: Front wheel inside seal question  (Read 4331 times)
Offline rdfmartin
« on: May 05, 2018, 04:15:15 pm »
I am replacing the rotors on a stock '86 Chevy K10, currently I am reassembling the rotor inside bearing and seal. Got the first seal an 8th of an inch past flush, got the second seal just right. Will having the seal a bit too deep be a problem? It is in evenly, just too deep. Guess the problem could be how it fits on the shaft.
Re: Front wheel inside seal question
« Reply #1 on: May 08, 2018, 05:25:31 pm »
refresh my memory but doesnt the seal have a shoulder that prevents it from going too far in?
« Reply #2 on: May 08, 2018, 08:06:09 pm »
No. As the old saying goes, do it right the first time. Buy another seal or carefully remove it and reinstall it so it is in correctly.
Offline carlnelson
  • 20 year Alaskan
« Reply #3 on: May 30, 2018, 05:44:59 pm »
ok Vile....  :)
I just did this this weekend too... and I was using a race installation set to put in new races... so I used the biggest one and thought it was bigger than the outside of the hub... so when driving it in it went too far in by at least a 1/4".... I looked at it and said.. what can it hurt?
ok, what will it hurt? Will it be destroyed by the inner bearings?
I'm planning a full removal and replacement of my front axel (Corp 10) to replace the inners (prob broken ring or pinion) So it will be all apart then but was just curious why does it have to be flush?
Thanks!
Offline Captain Swampy
  • Wisconsin
« Reply #4 on: May 30, 2018, 09:59:42 pm »
The races for the bearings get driven in until they stop. If you don't get them seated to the bottom, the bearings will push them in when you drive it. You need to check and see if they have loosened up. Or are you talking about the wheel seal?
Offline carlnelson
  • 20 year Alaskan
« Reply #5 on: May 31, 2018, 12:06:45 pm »
I'm talking about the Inner Wheel Seal, Vile and others have always been precise about driving them in until flush or maybe slightly below the inner hub, but I got it in a bit more than that, like almost a quarter inch in... I checked and it was not close to the inner bearing so I shugged and put it on as opposed to pulling it out and taking a chance on damaging it as I had no way to get another.... with my truck torn apart...
So just curious about the tolerances...
