Author Topic: SBC to BBC swap?  (Read 8036 times)
Offline gtfireftr
SBC to BBC swap?
« on: May 23, 2018, 04:53:06 pm »
I am a minute from purchasing a 1986 swb with a 305.... I will probable leave the engine until the winter, but then I am considering a BBC swap.... My question is will the BB just sit in the mounts of the SB??
TIA
Re: SBC to BBC swap?
« Reply #1 on: May 23, 2018, 08:52:07 pm »
just curious but why a BB? not saying dont but it will be cheaper and easier to mod the sbc. you could buy a 350 now and build it up (cam and heads) and have a decent power making engine for under 2k and you will be pushing 400 hp/tq.
« Reply #2 on: May 24, 2018, 07:57:52 am »
Ever owned a BBC? No comparison, it's the girth  8)
V8 mounting location is the same.
Offline Rattler12
  • Old Geezer
« Reply #3 on: May 24, 2018, 08:03:35 am »
There ain't no substitute for cubic inches ……..:)  Besides a 305 doesn't lend itself to getting the most bang for the buck with mods.  And there's not much difference in 10 mpg and 12 mpg. Beside a BB just looks awesome in a square body. To answer the OP's question the BB will bolt right in but needs its own mounts to the block
83 C-10 shorty 454, 5spd, 3:73 posi
Offline Stewart G Griffin
« Reply #4 on: May 24, 2018, 11:19:16 am »
DO You mean the clamshell mounts in the second picture?
i'm asking because i'm looking for a 3/4 suburban/crewcab or van...........and you know which direction i'm going engine-wise IF it comes with a BB..........
Offline Rattler12
  • Old Geezer
« Reply #5 on: May 24, 2018, 01:10:48 pm »
Those are the same...….. the "rubber"mounts that bolt to cross member are different but not by much. The hole in the BB rubber mount is a bit higher than the SB mount if memory serves
Offline ehjorten
« Reply #6 on: May 24, 2018, 01:59:39 pm »
The Truck Motor Mounts that bolt to the crossmember are different from SBC to BBC.
The SBC Truck mounts have this mounting pattern, but only use 3 holes:
The BBC Truck mounts have this mounting pattern:
The pieces that the motor mounts bolt to are swap-able, as they simply bolt in!
The difference in the pattern looks like this:
-Erik-
« Reply #7 on: May 24, 2018, 03:47:47 pm »
the more CI you push the more gas you need to feed. this is why the ecoboost is a decent motor in my mind. fuel saver when its not in use and the power when you need it. besides that stock vs stock yes the bb would be a better choice if you plan on towing all the time if you want an all around truck and care about MPGs sb or diesel imo. dont get me wrong a BB can outperform diesels and SBs but each one has its drawbacks
cant really argue that but like i said for around 2k (cam+ crate motor) you can have a 400 hp/tq motor and that will out perform most BB
