Author Topic: Bench Seat Suggestions  (Read 15627 times)
Offline Ronno6
  • Elder Student
« on: May 26, 2018, 02:49:03 pm »
What bench seats has anyone swapped into their 73-87 C10 ???
You can lead a man to water, but yoiu can't keep him from pissing in it.
Re: Bench Seat Suggestions
« Reply #1 on: May 26, 2018, 03:39:40 pm »
a little note the 88-98 style bench seats will be about 6" shorter (3" on each side) than our bench seats
Offline Ronno6
  • Elder Student
« Reply #2 on: May 26, 2018, 04:14:22 pm »
Good to know.
I had seen one of those that looked nice.
Thanks..........
« Reply #3 on: May 26, 2018, 04:28:36 pm »
some people have no issue with it but i know me being "wide" i might be finding myself between the door and the seat
« Reply #4 on: May 26, 2018, 10:53:37 pm »
Look for a 91 Suburban bench seat.  The only drawback is it is a fixed back.  It is firm and isn't the typical trampoline seat.  Very comfortable...
Offline Ronno6
  • Elder Student
« Reply #5 on: May 27, 2018, 10:13:41 am »
Is that going to be wider than the p/u seat pf the same vintage??
« Reply #6 on: May 27, 2018, 05:09:06 pm »
yes the burbs, crew cabs and 1 ton trucks will be the same from 73-91 (and blazers but theyll have bucket seats)
« Reply #7 on: May 28, 2018, 08:07:26 am »
Ask yourself this, is your butt worth it? If so, buy a nice seat. It makes driving your truck 100x more enjoyable. If you work hard, you deserve it.
This is my favorite aftermarket seat I have
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6233.390
This is my second favorite one, they are super comfortable, not trampolines, give you more room, fit perfect. Can't beat it
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5095.30
They are pricey but worth it. I also see them on Craigslist used from time to time if you're on a budget.
Offline ShogunK20
« Reply #8 on: July 26, 2018, 09:20:10 am »
I installed a 60/40 split bench in my 83. I fabbed a frame using the existing sliders. Couldn't be happier. Picked up the seats for $50 from a 95 being parted out.
Sent from my SM-G955U using Tapatalk
Offline cyberxen
« Reply #9 on: July 26, 2018, 05:35:04 pm »
That 60/40 is nice, what did you pull it out of? How is the fit side to side?
Offline ShogunK20
« Reply #10 on: July 26, 2018, 05:39:02 pm »
Fit is great, almost the same as the factory bench. These came out of a 95 Chevy extended cab
