Author Topic: carberator  (Read 15605 times)
Offline usmcchevy
carberator
« on: April 10, 2006, 09:27:00 pm »
what kind of carb do you recomend i put on my 250 striaght six. it has a 264 duration cam with .518 lift. i was thinkin either a holley 390 or edelbrock 500. which do you think is better.
Offline Z28 c10
Re: carberator
« Reply #1 on: April 10, 2006, 09:23:00 pm »
Personally, I'd go with the E-brock. I've had quite a few Holleys, and was never happy with them. The Edelbrock is a lot more user friendly. The only problem I've had with the E-brock is if you ever take the truck out on extreme angles they have a tendency to load up.
 JayTater
 Z28 C10
Offline 123 pugsy
Re: carberator
« Reply #2 on: April 11, 2006, 05:50:00 am »
Be very careful with carb size.If its too large,it will bog when you step on the gas hard.
Pugsy
76 C10 LWB
TPI 350
Offline usmcchevy
Re: carberator
« Reply #3 on: April 11, 2006, 06:17:00 am »
so do you think a 500 edelbrock will be ok for the 250 inline 6? is 500 the smallest edelbrock makes?
Offline 123 pugsy
Re: carberator
« Reply #4 on: April 11, 2006, 09:06:00 am »
You could google edelbrock to find  a tech line phone # maybe and talk to someone there. Worth a shot.
Pugsy
76 C10 LWB
TPI 350
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: carberator
« Reply #5 on: April 11, 2006, 11:14:00 am »
Try this...
edelbrock carbs
SgtDel
Offline 123 pugsy
Re: carberator
« Reply #6 on: April 11, 2006, 12:09:00 pm »
Thanks,Sarge.   Uh-oh , I shoulda checked first.Looks like my 600 might be too large for my 283.
Pugsy
76 C10 LWB
TPI 350
Offline usmcchevy
Re: carberator
« Reply #7 on: April 11, 2006, 02:07:00 pm »
looks like it will be ok. edelbrock says the 500 is good from 225 through 327 cubic inches. i think i'll go with the edelbrock 500.
Offline Redneckchevy
    • Photo Bucket
carbs
« Reply #8 on: April 11, 2006, 02:39:00 pm »
I run the Holley 600 on my 262 V6 And its fine ..all i had to do was run 2 inline fuel filters to slow down on the gas at take off....
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
carb
« Reply #9 on: April 11, 2006, 07:24:00 pm »
Hey, Pugsy, wanna borrow my 750 cfm for your 283???  I have the edelbrock 1407 on my 383 stroker.
SgtDel
Offline 123 pugsy
Re: carb
« Reply #10 on: April 11, 2006, 07:48:00 pm »
I dropped a 750 holley on my last 350 and it bogged .Ran OK on the 455. That 383 stroker must haul a@@ real good.
Pugsy
76 C10 LWB
TPI 350
Offline Z28 c10
Re: carb
« Reply #11 on: April 11, 2006, 08:37:00 pm »
I've got the 750 e-brock on my 350, Used to bog REAL bad. Then I did the cam change, then redid the cam change and installed a rebuilt set of old double hump 2.02 heads and 1.6 rockers. I had to jet up after break in. The truck went from getting 10 MPG to about 8MPG. Really sucks that I'm getting big block economy out of a small block. Oh yeah, the 3.73 gears probably aren't helping matters any.
JayTater
Z28 C10
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: carb
« Reply #12 on: April 11, 2006, 11:16:00 pm »
Oh, she hauls alright. I just wish there were no speed limits. I wish I could take it to Germany's  autobahn.
I have the 3:08 rear and it does real well on the interstate...the faster i take it, the happier she is.  It is an awesome feeling to go about 80 mph and punch it....she still has so much left in her (I can't tell how fast I actually had it once on I-95--let's just say hitting the three digit mark was nothing-nothing at all--it's unfortunate the speedo buries so easily).  The sports car drivers look puzzled when I pass them at those speeds.
I have the 1.6 rockers and an RV type cam. She sounds awesome when idling.
Oh, man, I get carried away...this isn't my topic, sorry.
SgtDel
Edited by: SgtDel at: 4/11/06 10:28 pm
Offline Z28 c10
383 Big 10 Police Intercepter
« Reply #13 on: April 12, 2006, 04:43:00 pm »
All you need Sarge is your 5.0 bubble light and a GPS, you'll see what she can do
Then slap in a couple bullhorns and blast some Ricky Scaggs as your sireen!!!
 JayTater
 Z28 C10
Edited by: Z28 c10 at: 4/12/06 3:45 pm
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #14 on: April 12, 2006, 07:07:00 pm »
Wouldn't that be awesome...going code 3 and thru the speaker,: "Uncle Pen played the fiddle, Lord how it would ring. You could hear it talk, you could hear it sing"
Going to a big bluegrass festival here next month, cant wait.  Gonna take theBlue Burb though.
SgtDel
