Author Topic: Throttle sticky when running  (Read 5548 times)
Offline Ronno6
  • Elder Student
« on: June 24, 2018, 02:01:32 pm »
This is a new one for me.
The accelerator is sticky when the engine is running.
Problem is with the Edelbrock carb.
If I disconnect the throttle cable and return spring, the butterfly shaft will return to
idle position with the engine not running.
Crank it up, the throttle will stick at whatever position I move it to and will not return to idle.
It is very sticky off idle.
I have cleaned the carb and sprayed WD40 on the butterfly shaft on each side without any improvement.
This really affects the smooth engagement of the clutch when leaving from a stop.
I am certain that it not the cable or pedal.
You can lead a man to water, but yoiu can't keep him from pissing in it.
Re: Throttle sticky when running
« Reply #1 on: June 24, 2018, 04:16:57 pm »
Take the carburetor off and clean/lube the throttle shaft bushings if that's what's causing it.
Offline Ronno6
  • Elder Student
« Reply #2 on: June 24, 2018, 05:04:24 pm »
Sounds reasonable.
I'll give Edelbrock a shout tomorrow to hear what they have to say.
Butterfly shaft gotta be the problem.
« Reply #3 on: June 24, 2018, 05:36:07 pm »
Is it new?
Offline Ronno6
  • Elder Student
« Reply #4 on: June 24, 2018, 09:59:38 pm »
No, but I don't know how old.............
Offline Ronno6
  • Elder Student
« Reply #5 on: June 25, 2018, 10:33:53 am »
Geez..........the Edelbrock guy was NO help!
Of course, he zeroed in on the fact that a 600cfm carb was too large for my 305,
he had no answer for the thing sticking when motor is running.
I indicated that I may move up to a 350, but if "his" carb was not going to free up,
I may replace it.
He replied "that would be a good idea!"
SOME customer support and tech help!
Offline Ronno6
  • Elder Student
« Reply #6 on: June 25, 2018, 01:31:50 pm »
Polishing and lubing the throttle shaft made a major improvement.
I was also able to ease off on the return spring as the carb returns to idle without
the previously increased  tension.
I can drive it now without sounding like a rank amateur.......
Thanks!
« Last Edit: June 25, 2018, 03:34:47 pm by Ronno6 »
