Author Topic: Throttle/Kickdown bracket bolt size/specs?  (Read 10462 times)
Offline klittl06
« on: June 29, 2018, 08:03:33 pm »
Hi All,
I just got my hands on a 76 C10 Silverado with a sbc 350 and th350.  Overall it's in pretty solid shape, but the previous owner did some odd things.
Anyway, the throttle/kickdown bracket is missing one for the bolts that secure the bracket.  I can't seem to find any info on it searching online or in the service manual.
Does anyone know what what spec/size bolt I need?
Thanks,
Kyle  :D
Re: Throttle/Kickdown bracket bolt size/specs?
« Reply #1 on: June 29, 2018, 08:18:46 pm »
depending on the bracket and how it's mounted, 5/16-18 or 5/16-24 or 3/8-16
pics would help
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: June 29, 2018, 08:59:39 pm »
Welcome.
Mopar by Birth
Chevy by Choice
Offline 75gmck25
« Reply #3 on: June 30, 2018, 06:08:53 am »
Where is the bracket mounted?
On my '75 K25 with 350/TH350 the TH350 kickdown bracket is bolted to the last two bolts for the intake manifold, and my throttle bracket is bolted to the rear two bolts on the Quadrajet.  I'd have to look up the sizes, but both of these are very standard bolts.
FYI - The 2nd to last bolt on the intake (and several other intake bolts) has to be sealed with RTV to prevent oil seepage.  The last bolt on the back of the intake is into a blind hole and does not require sealant.
You should also check the adjustment on the TH350 kickdown when you reinstall it, since midadjustment may make it not downshift properly.  The procedure is to:
- Pull up on the small tab on the top of the cable grommet/end, which releases the cable adjustment
- Then manually pull the carburetor to full throttle so that it fully extends the kickdown cable
- Then push the tab back down to lock it again
Bruce
Offline klittl06
« Reply #4 on: June 30, 2018, 10:11:21 am »
Hey All,
Thanks for all the feedback and welcomes!
Here's a link to a couple photos - https://drive.google.com/drive/folders/1-SNiOlDHfiiSgoHDgPNocEufvBelhMmp?usp=sharing
As you can probably tell, I've got a lot to do (hopefully in time).  I'm looking to get her driving and inspected before digging too deep into things.  The kickdown cable definitely needs to be adjusted, it's not even attached to the carb at the moment  ::).
And thanks for the info, I'll check out those intake manifold bolts!
Thanks again!
« Last Edit: June 30, 2018, 10:40:10 am by klittl06 »
Offline roger97338
« Reply #5 on: July 28, 2018, 01:41:19 pm »
What is this bracket's purpose?
Offline klittl06
« Reply #6 on: July 28, 2018, 01:44:27 pm »
That bracket is for the AC compressor.
I still need that bolt for the kickdown bracket but I've realized that I either have the wrong bracket or wrong cable.  I'm probably going to push this aside until the truck passes inspection.
Sent from my SM-N950U using Tapatalk
Offline blazer74
« Reply #7 on: July 28, 2018, 06:43:29 pm »
Could be the wrong throttle/ kick down  bracket.
Offline blazer74
« Reply #8 on: July 28, 2018, 06:53:19 pm »
Should be one piece bracket across the 2 rear bolts on the carb. Search for quadrajet parts online to find the correct stud for the throttle linkage. The kick-down just slides over the lower inner stud on the throttle linkage then adjust the kick down as in previous post.
« Last Edit: July 29, 2018, 01:01:10 pm by blazer74 »
Offline blazer74
« Reply #9 on: July 29, 2018, 04:40:15 pm »
Throttle bracket
Offline klittl06
« Reply #10 on: July 29, 2018, 05:31:12 pm »
Throttle bracket
Thanks for the clear pic.
https://drive.google.com/folderview?id=1-SNiOlDHfiiSgoHDgPNocEufvBelhMmp
Something definitely off with mine. As it sits the black plastic at the end of the kickdown cable makes it too long.
I added a picture the album above.
Any ideas?  The PO was rather creative from what I've seen so far...
« Last Edit: July 29, 2018, 05:33:30 pm by klittl06 »
Offline blazer74
« Reply #11 on: July 29, 2018, 06:06:37 pm »
There is a different  bracket for the Kick down as well. It also holds plug wires and has a hole in it for the brake booster line to pass through.
Can’t say where that bracket came from on yours.
I run vortex heads so I can’t use the stock kick down bracket so no pic.
If I find it I’ll take a pic of it. Hard to say what I did with it.
The Performer 2101 will accept the original kick down bracket if you get one.
When you get it all together and you set your kick down adjustment have someone hold the pedal to the floor to get a more correct setting.
Offline klittl06
« Reply #12 on: July 29, 2018, 07:32:31 pm »
Awesome info!
I've been digging some. I added another picture to the album of what I think might be the stock bracket. Would you mind taking a look?
Besides that I think the Edelbrock 8036 might be able to work although it's very different that what I found.
Thanks
Offline blazer74
« Reply #13 on: July 29, 2018, 08:42:18 pm »
Awesome info!
Thanks
That bracket looks a little more complicated than mine but couldn’t say.
The EDL universal goes every which way but have no experience with it.
I used a spectra kick down bracket in combination with my own creation.
Offline blazer74
« Reply #14 on: July 30, 2018, 10:12:43 pm »
Here’s the factory 1974 kick down bracket 350/350
