Author Topic: 87 r10 a/c blows cold then warm  (Read 9376 times)
Offline lehman368
« on: July 10, 2018, 06:20:19 pm »
On my 87 a/c blows cold then after running for hour or so it will start warming up and seams the air flow through the vents slows down. When you shut it off it seams to drip a lot of condensation water.
Re: 87 r10 a/c blows cold then warm
« Reply #1 on: July 10, 2018, 06:38:41 pm »
The evaporator is freezing over.  What are the system pressures?
Offline lehman368
« Reply #2 on: July 10, 2018, 08:34:46 pm »
Offline lehman368
« Reply #3 on: July 10, 2018, 08:37:54 pm »
I don’t have a pressure regulator for a/c. If I can find one From a friend I will check. Upper and lower? What pressures should they read at?
« Reply #4 on: July 11, 2018, 05:47:44 pm »
If you have access to the proper manifold gauge set, you can monitor your operating pressures and report them back. Has the system been retrofit? What refrigerant is in it?
Offline lehman368
« Reply #5 on: July 12, 2018, 12:45:23 am »
Yes it has been retrofitted before I bought it. It would blow cold last summer but really never drove it on longer than 45min trips. Now after working on the truck this past year. I have been driving it more and taking it on longer trips. Real Big headache last weekend on a 3and 1/2 hour trip in 90 + degree heat. Stoped cooling after about 50 mins.
Offline lehman368
« Reply #6 on: July 12, 2018, 12:47:44 am »
The new refrigerant I think. I have not been able to find any one the has proper gages yet. After it thaws out it cools the same. We stopped to eat, when I came back out to the truck there’s a big puddle under it 3x6 foot spot.
« Last Edit: July 12, 2018, 01:06:43 am by lehman368 »
Online Rapid Roy
  • Euless, Texas
« Reply #7 on: July 12, 2018, 06:12:29 am »
Welcome to the site.
Mopar by Birth
Chevy by Choice
« Reply #8 on: July 20, 2018, 11:40:12 pm »
welcome from maryland, low Freon can cause the core to freeze up but like vile said get a manifold gauge set and see what the readings are
