4 Wheel Drives
4WD Front Wheel Bearing Pre-load?
Topic: 4WD Front Wheel Bearing Pre-load? (Read 38003 times)
Jon87V20
July 14, 2018, 02:40:58 pm »
I'm replacing both front rotors, hub assemblies, calipers, and all wheel bearings on my '87 Suburban V20 today.
I'm trying to figure out what to do about the bearing pre-load. I'm getting some conflicting information when I'm looking around about this. I'm seeing videos where people are pre-loading the bearing to 50 ft-lbs., then backing it off an eighth of a turn, I'm also seeing in the Service Manual PDF that you should never pre-load the front bearings as it will cause premature failure.
When I took the driver's side apart yesterday, the outer spindle nut was basically finger tight, and the inner one didn't take much effort to get out either.
Any advice is much appreciated as I would really like to get this all back together today. Need the truck for work on Monday.
Thanks!
1987 Chevrolet Suburban V20 Silverado
350ci TBI TH400 NP208
Re: 4WD Front Wheel Bearing Pre-load?
July 14, 2018, 04:53:05 pm »
Adjust the bearings by rotating the hub and tightening the inner adjusting nut to 50 ft. lbs., then loosening it and retightening to 35 ft. lbs. Next, back the nut off 3/ 8turn or less. Turn the nut to the nearest hole in the lockwasher. Install the outer locknut and torque to a minimum of 80 ft. lbs. (108 Nm) on 1980 models, 160-205 ft. lbs. (216-277 Nm) on 1981 and later 1/ 2and 3/ 4ton models, and 65 ft. lbs. (88 Nm) on 1 ton vehicles. There should be 0.001-0.010 in. bearing end-play. This can be measured with a dial indicator.
Jon87V20
July 15, 2018, 01:47:17 am »
Ok. Thanks, Vile. By the way, I have to ask, what's going on in your profile picture there? Some kind of action figure or something?
July 15, 2018, 06:25:14 am »
It's the toy that became Omega Supreme (pre-transformers) and I got it for my birthday when I was a kid. My buddy came over to play and broke it, of course I got mad at him and he would always bring it up every time I saw him. He committed suicide unfortunately so I changed the picture to commemorate our friendship.
Jon87V20
July 16, 2018, 12:49:06 am »
Vile, sorry to hear about your loss. Pretty awesome robot. Thanks again for the help.
July 16, 2018, 05:26:33 am »
Thanks - Good luck
JohnnyPopper
Old Goof
December 25, 2018, 06:03:18 pm »
VZ, thanks for sharing the backdrop of your avatar. I've tried to enlarge it, gave up thinking it was a pic of a motor... Sorry for your loss too.
I have the same 4X setup and need clarity on your instructions to 'back off 3/8 of a turn', do you mean 135 degrees?
Thanks!
1980 C-10 under construction
December 26, 2018, 07:01:36 am »
Yeah I'm about due to update the Avatar...
Just turn it back less than a 1/2 turn and then retighten to the next locking position.
75gmck25
1975 GMC K25 Camper Special, 350/TH350/NP203
December 26, 2018, 07:25:34 am »
The procedure Vilezambonie described is just about word-for-word from the repair manual.
- The 50 ft lb initial tightening sets the bearings into the races. You will feel it pulling the hub in tightly and squishing out the grease.
- Then you loosen the nut and tighten it again to 35 lbs while rotating the hub. This is really the part that puts a preload on the bearing.
- Then you back it off just enough to get the locking ring/washer to match up with one of the holes. The locking washer is keyed, so it only goes on in one position. That is why the washer and nut (pin and holes) might not line up at first. The book says you can back off no more than 3/8ths turn, but I've never had to back it off that far.
- Now you put on the final lock nut and tighten to 80 ft lbs (my '75 book says 50 ft lbs minimum), which keeps it all in place.
Bruce
JohnnyPopper
Old Goof
January 02, 2019, 12:59:37 pm »
Thanks guys, I did the math and 3/8 is 130 degrees, sound like a lot, will play with it.
MIKE S
Member
January 02, 2019, 02:10:47 pm »
When adjusting the bearings, keep in mind if you have auto locking hubs they are engaged on the wings of the locking washer. That being said if they are not torqued to a minimum of 160 ft. lbs. the action of the auto hubs will work on the washer and tear up the spindle keyway and threads along with unscrewing the nut that will lead to catastrophic failure.
JohnnyPopper
Old Goof
January 03, 2019, 04:57:18 pm »
Thanks Mike, she's too old for that type of thomfoolery, 1978
Hawaiian Rust Fighter
New Users
December 28, 2022, 11:07:55 am »
Had a mechanic buddy finish up my passenger side and he put the inner adjuster nut in backwards and I'm guessing he just slid the washer on then tightened the outer nut to 60. I thought he said 160. My fault not checking, because about 3 weeks later I got death shake, tightened my tie rod ends... 1 week later: death shake, found 2 lug nuts cross threaded, replaced... 1 more week and - murder shake. While cruising on a curvy highway at 40-45mph, passenger wheel hit a tiny pothole and the truck started shaking so bad that I literally got shaken out of my seat belt and thrown to the passenger side as my Suburban rocked left and right hard enough to blow a tire and flip over twice, ending up in the opposite lanes and got hit by a Home Depot delivery truck. Surprisingly, I only had a concussion, sprained wrist and bruises across my waist and up and down my shins and knees. My truck was totalled, obviously, as was the home depot truck, driver thankfully unscathed. Cost my insurance to pay out 82k in small claims, they cut me and now I am driving a 93 camry that smells like cats, rats and mildew all got together and had a super-demon spawn child that lives in the everything (Inames her Putridfer), with 290,000 miles of no fun and have an sr22 now. Point is - either do your own work and be liable or take it to a shop and have them be liable, do NOT have a buddy tell you lies and believe him without taking a good look of his work.
Women seem great in theory, but the reality is my Chevy is better.
1987 Chevy Suburban V20, 1989 Chevy Suburban 2500
JohnnyPopper
Old Goof
December 28, 2022, 11:38:18 pm »
#Whatisalamestoryaboutcats?
Jon87V20
December 29, 2022, 07:28:43 pm »
Yeah. That's an intense story. Sorry about your situation, dude.
4 Wheel Drives
