Author Topic: Best suspension conversion kit  (Read 5743 times)
Offline Mjfreuland
« on: July 14, 2018, 05:42:37 pm »
74 c10 swb here. I'm looking for the most streetable suspension conversion kits. Front and rear. Not drag racing or anything. Just for smooth daily driving. Not trying to drop it too much either. Closer to stock height. Adjustable if need be.
Re: Best suspension conversion kit
« Reply #1 on: July 15, 2018, 07:04:55 am »
Conversion to what exactly? Wanting to improve ride quality doesn't necessitate a conversion. You should inspect the steering and suspension, replace any worn components, etc. Is your goal to improve the ride or to lower it? Both?
Offline Mjfreuland
« Reply #2 on: July 18, 2018, 01:15:41 pm »
I want to get a nice smooth ride and achieve this stance.
« Reply #3 on: July 18, 2018, 05:42:28 pm »
Lowering shackles, Lowering spindles, good quality shocks
Offline Mjfreuland
« Reply #4 on: July 19, 2018, 01:04:55 am »
Brands? Front and rear? Any complete kits?
« Reply #5 on: July 19, 2018, 06:09:47 am »
You really need to do your homework based on your particulars and the end result you are looking for. If you are keeping the same wheels and tires, will they fit with 2" spindles still? Is a 2" drop what you are looking for? Do you want to go lower? Will the wheel contact the lower control arm if you go that route and keep your wheels? Do you need spacers or different wheels? How many leaves do you have? Are the suspension components in good shape? Springs not fatigued, bushings good? My suggestions is to measure everything, check everything, create a list of parts you will need and action items. summitracing is a good source but there are many others out there too. Sounds like you will need, lowering spindles, shackles, shocks, boots, & maybe wheel spacers, to begin with. Once you start changing to lowering springs and removing leaves the ride quality will be altered.
