Author Topic: Carb to tbi conversation  (Read 18396 times)
Offline st3vomettler
« on: August 01, 2018, 08:03:58 pm »
I’m converting my 77 c10 from carb to tbi. I took the wiring harness inside and out, intake, tbi and all sensors needed. I have a donor 90 c1500 that all the parts came off of. I’m getting spark but no fuel it will start with gas squirted in to tbi but pump and injectors won’t work. Need help please
77 c10 Silverado 350 nv3500 5spd
Re: Carb to tbi conversation
« Reply #1 on: August 01, 2018, 10:54:26 pm »
Check the ECM-I (ignition power) and ECM-B (battery power) fuses in the fuse box using an incandescent test light.  Make sure all of the ECM grounds are properly connected and 100% functional.  Measure the fuel pressure using a proper gauge.  Will it start if you connect a fused jumper wire between battery positive and the 4" red pigtail with a single black connector at the fuel pump relay?
« Reply #2 on: August 02, 2018, 06:08:48 am »
I don’t have a test light but I did change the two fuses with new ones and there isn’t a 4” red wire coming out of my fuel pump relay pig tail but there is a smaller red wire and I jumped it to battery and still nothing and all grounds are bolted down.
« Reply #3 on: August 02, 2018, 08:44:40 am »
You need to determine whether there is power at the two ECM fuses - I recommend that you procure a test light.  Post a pic of the fuel pump relay
« Reply #4 on: August 02, 2018, 03:21:18 pm »
this might help you
the red wire is the "C" plug
« Reply #5 on: August 02, 2018, 03:24:24 pm »
« Reply #6 on: August 02, 2018, 05:55:46 pm »
I’m getting power to both fuses but no power to fuel pump
« Reply #7 on: August 02, 2018, 06:08:19 pm »
are you getting power to the relay? what happens when you connect B+ to the red wire "C" on the relay.
« Reply #8 on: August 02, 2018, 06:08:53 pm »
but x2 on this
« Reply #9 on: August 02, 2018, 06:17:17 pm »
The picture of the fuel relay won’t upload it’s to big but the wires are org, grn/wht, rd/blk, rd/wht and blk/wht
« Reply #10 on: August 02, 2018, 06:49:39 pm »
this one?
« Reply #11 on: August 02, 2018, 07:11:09 pm »
I checked fire at fuel relay pig tail only got fire at orange wire and when I jumped orange wire to other wires nothing happened but the black wire sparked
« Reply #12 on: August 02, 2018, 07:39:52 pm »
The black/white wire is relay ground.  Orange is B+ powered through the ECM-B fuse.  Green/white is relay control from the ECM.  Do you know how to read a wiring diagram?  Do you have a voltmeter?
« Reply #13 on: August 02, 2018, 07:51:20 pm »
dont jump wires unless you understand how they work. if you jumped orange to black you prob blew a fuse.
« Reply #14 on: August 02, 2018, 09:05:14 pm »
All furs are good and the fuseable links are getting power past them and yes I have voltmeter and no I don’t really now how to read them not my sting suit
