Author Topic: spongy brakes  (Read 6961 times)
Offline 83Bulik
spongy brakes
« on: September 24, 2018, 04:29:18 pm »
I have an 83 C10 and whenever i bleed the brakes they feel stiff up until i start the truck up. I think it might be my vacuum booster but im not completely sure. Any ideas or suggestions?
Re: spongy brakes
« Reply #1 on: September 24, 2018, 06:06:59 pm »
That's how it works. The booster is aiding in reducing the effort needed. Spongy brakes means, the pedal sinks due to compressing air trapped in the fluid lines.
Offline 83Bulik
Re: spongy brakes
« Reply #2 on: September 24, 2018, 08:29:57 pm »
So u think that i should just continue to bleed them? Thank u very much!
Re: spongy brakes
« Reply #3 on: September 25, 2018, 09:49:23 pm »
if you have spongy brakes all the time then yes bleed them, if you have brakes that go to the floor with or without the vacuum booster then you have air in them. if your brakes do sink to the floor have have resistance once the truck is started they might be working fine. these trucks dont really feel like a 90s+ truck with their brakes but once you get the feeling you will never forget how the brakes feel.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=33548.0
theres a "trouble shooting" section on that page take a look
Offline Ronno6
  • Elder Student
Re: spongy brakes
« Reply #4 on: September 26, 2018, 05:09:38 pm »
I had tried several ways to bleed the brakes on my '84 C10 and was not satisfied with pedal firmness.
Then I used the gravity-bleed method and achieved the feel I was looking for.
YMMV
You can lead a man to water, but yoiu can't keep him from pissing in it.
Offline roundhouse
Re: spongy brakes
« Reply #5 on: October 03, 2018, 07:07:17 am »
YMMV
I always did the gravity bleed because I was lazy or didn’t have a victim to pump the pedal
Seems to work pretty well
Re: spongy brakes
« Reply #6 on: October 03, 2018, 07:23:22 am »
ive always gravity bleed mine also, i think for the same reason as you lol. my friend on the other hand seamed like he preferred to have someone pump them or he got one of those brake pumps that pushed the fluid up (which didnt work too well). but most the times when he had issues i would suggest to use gravity and im sure 9 out of 10 times it worked
