Author Topic: More power  (Read 4808 times)
Offline Gusgusa1
  • Gasket
More power
« on: October 05, 2018, 10:41:11 am »
I put some lights and am putting on a warn 10,000lb winch on my truck as I work in the bush in the winter 🇨🇦
My headlights before the additions would drop my volt metre dangerously low but with out them it always reads full charge.
I'm thinking I need a high capacity alternator does anyone have any suggestions?
Next summer I'll be putting in dual batteries as well. At least that's the plan.
1987 k10 350TBI,
2002 gmc 1500hd 6.0 4x4
1987 gmc Sierra classic 1500 350ss 4x4
1986 silverado 350 4x4
1984 scottsdale 305 quad jet 4x4 4spd manual
1982 camaro z28 350 w vortec heads spool
« Last Edit: October 05, 2018, 11:40:42 am by zieg85 »
Re: More power
« Reply #2 on: October 05, 2018, 11:58:44 am »
X2 on the headlamp relay kit regardless of whether you upgrade the charging system.
For alternator upgrades, take a look at...
Stupid-simple alternator upgrade -- 55A to 94A
AND
Powermaster 57294 150A alternator or similar products.
You will need to install larger gauge charge leads with a charging system upgrade to enjoy full benefit.  Depending on your circumstances, you should also consider a battery isolation system when installing a second battery.  The type of system will be dependent on your specific purposes.
Offline Gusgusa1
  • Gasket
Re: More power
« Reply #3 on: October 05, 2018, 04:02:20 pm »
Are you saying a relay will draw less power? How does that work?
Offline Gusgusa1
  • Gasket
Re: More power
« Reply #4 on: October 05, 2018, 04:04:55 pm »
Would I need 2 harnesses I have quad lights.
Re: More power
« Reply #5 on: October 05, 2018, 04:58:24 pm »
Look for one for the 4 headlight system.  The relays take the load off of the headlight switch
Offline 75gmck25
Re: More power
« Reply #6 on: October 06, 2018, 07:36:04 am »
The original alternator in our trucks was a 10si, which came in versions up to a 63 amp.  The cheapest budget choice is to directly replace it with a V-belt 12si that puts out 94 amps.
All you need to do is buy a rebuilt Delco 12si with the right clocking and a V-belt, bolt it in, and upgrade your charge wire to an 8 gauge wire.  This site has info on the stock systems and how they differ. http://www.madelectrical.com/electricaltech/delcoremy.shtml ,  If you are interested I can look up the lester number (parts exchange catalog) of the 12si I used on my '75.
The other common choice is to upgrade to a newer CS130.  Its also a good upgrade, and the alternators put out more, but it gets a little more complicated than a simple swap to a 12si.
I did both the 12si swap and the headlight relay upgrade on my truck.  I also added a junction on the passenger fenderwall to connect it all together, and use that for the new charge wire connection.
Bruce
Re: More power
« Reply #7 on: October 06, 2018, 09:55:04 pm »
The relay allows you to deliver a high current load with a low current control. The factory design provided current to the headlights directly through the switch. The unwanted voltage drops result in reduced performance however this will not improve your charging system output. Tackle that upgrade first and go from there if you are in need of getting better lighting.
