Author Topic: 2001 Silverado 2500HD heater switch?  (Read 6900 times)
« on: November 08, 2018, 07:46:16 pm »
My truck doesn't have factory AC as it is just a plain work truck.  I have a 6 position switch off then 1-5.  My blower works on 4 and 5 only.  I am thinking it is the fan resistor but usually just the highest position works.  Am I on the right track or should I be looking to replace the fan switch.
Re: 2001 Silverado 2500HD heater switch?
« Reply #1 on: November 08, 2018, 07:56:46 pm »
Just a blower relay I take it???  I don't see the resistor like our truck have.
« Reply #2 on: November 09, 2018, 04:36:26 am »
Yes there is a resistor and it is most likely your issue. See #5
« Reply #3 on: November 09, 2018, 07:32:34 am »
Thanks Vile!!!  I will locate it and check it out.  Looks to be under the dash passenger side
« Reply #4 on: November 09, 2018, 05:30:57 pm »
know on my 02 ive had issues with the resistors and the connector. but unlike you i have 1-4 and Hi doesnt work unless i wiggle the connection. but the resistors are a known issue and will overheat
« Reply #5 on: November 09, 2018, 05:38:43 pm »
my luck I will have a burnt up plug it...  On a positive note I snagged a very nice topper today.
« Reply #6 on: November 09, 2018, 05:45:39 pm »
well at least you have that going for you lol
« Reply #7 on: November 30, 2018, 10:28:51 am »
$29+ later I have all speeds now.  Thanks Vile!!!
