Author Topic: Th400 shifting issue  (Read 3725 times)
Offline Joe.cummings
« on: December 11, 2018, 09:07:04 am »
Issue: th400 not shifting correctly. Feels like when the truck shifts into 2nd that first gear does not disengage.
Additional information: I never used this transmission before so I do not know the history of the trans. Also, I did do a complete rebuild including installing a 4l80 direct drum and 32 element sprag. It does need to be said that this is my first trans rebuild and I easily could have messed something up.
I did replace the vacuum modulator and ensured the vacuum line is coming from manifold vacuum. Any help is greatly appreciated.
Offline Rapid Roy
  • Euless, Texas
Re: Th400 shifting issue
« Reply #1 on: December 11, 2018, 09:08:14 am »
Welcome
Mopar by Birth
Chevy by Choice
Offline Ozark
« Reply #2 on: December 11, 2018, 10:29:33 am »
Maybe worth replacing the check valve at the brake booster?
« Reply #3 on: December 11, 2018, 02:52:51 pm »
Why would this cause an issue?
« Reply #4 on: December 12, 2018, 04:26:05 am »
Disconnect the detent solenoid to see if any change.
Recheck the manual valve before you pull it apart.
