Author Topic: Upper rear shock mount - frame tweaked not cracked  (Read 5561 times)
Offline ctandc
« on: December 17, 2018, 03:53:40 pm »
1984 GMC K1500 SWB 4x4. Driving project. Went to replace the overload shocks on the rear that have probably been there for 20 years and luckily I randomly started on the passenger rear.
The upper shock stud is angled downwards. The stud itself doesn't appear bent - it's the frame - it seems tweaked where the stud is. No cracks. Only pics I have.
Any reason I can't heat that area up with a torch and beat the stud / frame back into a decent alignment then replace the stud?
Offline Rapid Roy
  • Euless, Texas
Re: Upper rear shock mount - frame tweaked not cracked
« Reply #1 on: December 17, 2018, 04:51:09 pm »
Welcome
Mopar by Birth
Chevy by Choice
« Reply #2 on: December 18, 2018, 04:55:09 pm »
Without heating it, see what happens if you try to bend it back into position. If it goes, the frame is weak and you will need a reinforcement bracket. That frame looks neglected and in need of some TLC. Also get new mounts for after you are done repositioning it.
Offline AZ4X4SQBDY
« Reply #3 on: December 22, 2018, 01:08:38 pm »
That's kind of weird, the shock was too short constantly pulling down on it. Usually they get bent up from too many "hold my beer and watch this!" stories where they jumped it or bottomed its out too many times. I've got one like that now and I am going to try to use a large hardened washer to do the repair of the damaged area.
1987 GMC Sierra Classic 4x4 short, fleet, 1985 Chevrolet Silverado 4x4 short, step side, '87 Chevy Silverado short fleet, '91 Dodge Ramcharger LE 4x4,
2005 Porsche Boxster S,1982 Alfa Romeo Spider Veloce
