Author Topic: 350 Timing (keeps going out of whack!)  (Read 5353 times)
Offline ChevySepticGuy
« on: June 18, 2006, 10:58:00 am »
Hey guys,
It seems like my timing keeps going out of whack. Just when i think that the bolt is tight I'll hit a pot hole or go down a bumpy road and the timing goes in her.
It still has a great sounding idle, but when she is moving down the road it almost makes a "chug, chug, chug" sound when i hit the gas pedal. similar to a "hole in the exhaust" type of sound.
So i'm assuming her timing is now set too low. :\
Is there any way to fix the timing so that it won't go out? like putting a lock washer or something on that clamp down bolt?
I'm sure this is a common question! So i'm sorry if it's been asked a hundred times. :p
Thanks guys.
"Chevy Septic Guy"
1985 Chevrolet Custom Deluxe C30 (1 ton)
Offline roundedline
Re: 350 Timing (keeps going out of whack!)
« Reply #1 on: June 19, 2006, 02:29:00 pm »
Is it tightened down?  There should already be a lockwasher there, but..
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
« Reply #2 on: June 20, 2006, 03:26:00 pm »
Found out that my "chugging" is due to a spark plug wire that was touching manifold and grounding out. :rolleyes
"Chevy Septic Guy"
