Author Topic: Issues with power to 87 fuel pump  (Read 4994 times)
Offline Cb8128
« on: January 18, 2019, 10:45:14 am »
I have a 87 Chevy 3/4 ton and the fuel pump will not turn on when turning the key. This had been a off and on issue for the last few months And we were able to pour a small amount of fuel in the throttle body and she would take off. We are trying to figure out our issue. So I found the fuel pump relay and put 12 volts to the pigtail and the pump did turn on so I believe that the fuel pump it's self is fine. We bought a new fuel pump relay today thinking maybe it was a bad relay and that did not do the trick. We also got a new fuel tank selector switch bc anytime someone bumped the switch with their knee it was always a pain to get it to start working again. What do I need to check next? Possibly the oil pressure sensor? Thanks for any info you all can give me
Re: Issues with power to 87 fuel pump
« Reply #1 on: January 18, 2019, 02:40:43 pm »
Check the fuses, see if it's equipped with the fuel module. Refer here:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9072.0
