Author Topic: Location of factory bus bar ground near instrument panel?  (Read 8075 times)
Offline ken4444
« on: February 05, 2019, 07:13:15 pm »
I was looking over the '83 schematics to figure out where the wiper motor grounds (A reply to my build thread said the wiper motor grounds at the wiper switch), and I noticed that black #150 wire from the wiper switch goes to a gigantic splice which goes to a "BUS BAR GND" on the schematic with a saw blade-like icon on it (see pic below).   Is that correct and where is this physically located? What does it look like?   Does anyone have a photo?
If I can find a bus bar ground and clean it up, I might also be able to fix my fuel gauge problem AND my slow wipers.
Schematic:
http://www.73-87chevytrucks.com/techinfo/7387CKMans//Wiring/ST386_83_1983_GM_Wiring_Manual_CK_P_G_10_to_30_and_ST.pdf#page=9
Re: Location of factory bus bar ground near instrument panel?
« Reply #1 on: February 05, 2019, 07:20:19 pm »
Behind the LH dash vent area and before the parking brake mechanism.
Offline ken4444
« Reply #2 on: February 05, 2019, 07:23:12 pm »
What's the easiest way to get to this?  From below?  Or above with the instrument panel out?  Or both?
How big is this bus bar?
« Reply #3 on: February 05, 2019, 07:33:07 pm »
Under the dash unless the dash bezel and vent (if equipped) is removed.
Offline ken4444
« Reply #4 on: February 05, 2019, 07:52:59 pm »
Thanks for the details.  How likely is it that I can clean this assembly up and improve any ground-related problems?  This would seemingly be a must-do for any square body owner.
Offline 75gmck25
« Reply #5 on: February 06, 2019, 07:32:36 am »
Cleaning up grounds is always a good idea, and having a single common ground point makes electronics much more stable.  When I installed a wide-band AFR gauge the directions were very clear about a single ground, because you are measuring such small voltage differences with the gauge.
FYI - on the older trucks like my '75 there is no ground bar.  They just grounded the instrument panel to a post on the emergency brake mechanism.
Bruce
« Reply #6 on: February 08, 2019, 04:16:06 pm »
You sure about that? My 74 and 75 have it.
