Author Topic: dakota digital vhx gauges problems  (Read 6042 times)
Offline 77c10sb
« on: February 07, 2019, 10:53:04 am »
hey guys im in the middle of my install of my vhx gauges and im having issues with my turn signal.  everything is working fine however whenenver i turn my headlights on the blinkers stops working, when i turn them off they work again. anybody had this issue
Re: dakota digital vhx gauges problems
« Reply #1 on: February 07, 2019, 11:27:34 am »
Check the basics first and verify that the cluster is properly grounded through its various jumpers and connections all the way back to battery negative.
Offline 77c10sb
« Reply #2 on: February 08, 2019, 11:30:00 am »
well im grounding the vhx box to the ebrake housing.  im using 18gauge ground wire which is the minimum requirement.  u think it could be a bad headlight switch that is doing this?
« Reply #3 on: February 08, 2019, 12:31:27 pm »
I think it has a floating ground and there is nothing wrong with the headlamp switch.  The 18-gauge ground wire should be adequate for the application.  See the article, Ground.
