Suburbans
Top shock hole wallowed, go inboard?
Topic: Top shock hole wallowed, go inboard? (Read 19237 times)
4inthefloor
March 24, 2019, 04:27:54 pm »
I recently discovered the top shock bolt loose on my 84 3/4 ton suburban. I'll attach a picture of it. There's no cracks, but I'm wondering. I've been thinking of moving my shocks in board, but looking for suggestions on the wallowed hole. Should I just clean it up/paint it and leave it alone or is there any repairs I should do to the hole, what's the likelihood of it developing a crack without the shock beating on it?
cffisher
Re: Top shock hole wallowed, go inboard?
April 11, 2019, 05:36:59 pm »
I think I would plug the hole then redrill it to fit. Plug it with same thickness material, and weld in.
Retired and loving it.
roundhouse
April 12, 2019, 06:47:47 am »
Could weld a thick washer on each side
Easier than plugging and drilling
JohnnyPopper
Old Goof
April 12, 2019, 12:36:35 pm »
Drill another hole to the right about 1" and get it back on the road!
Prime and paint the oblong hole.
There, fixed it.
1980 C-10 under construction
4inthefloor
April 12, 2019, 06:29:14 pm »
Good ideas, from all of you guys. I'm gonna weigh my options, not in a real hurry as it's just sitting around right now after an engine swap and finishing up the fuel system. But I wanted to get some more eyes and opinions about it. Thanks
April 12, 2019, 06:40:35 pm »
Quote from: roundhouse on April 12, 2019, 06:47:47 am
This
⌠ŻŻŻŻŻ' [☼===☼]
blazer74
April 15, 2019, 04:09:08 am »
Weld thick washers then get the shock bolt reinforcement brackets or make them. Do an internet search.
Stewart G Griffin
April 15, 2019, 01:12:23 pm »
What causes this? i had the same problem on the rear control arms/trailing(?) arms of a GM FWD car.
April 15, 2019, 05:52:21 pm »
Loose shock mount
⌠ŻŻŻŻŻ' [☼===☼]
Suburbans
