Author Topic: Fuel Pump Question  (Read 8600 times)
Offline wilrob
Fuel Pump Question
« on: April 17, 2019, 09:04:31 pm »
I am looking at ditching my saddle tanks for a rear mount. The blazer tank seems to be the most economical "stock" way to do it, but my question is can I use an external electric fuel pump with the stock sending unit/fuel pickup? I will be converting to EFI down the road but I don't want to run an internal pump.
1983 LWB Silverado 305sbc
Re: Fuel Pump Question
« Reply #1 on: April 18, 2019, 05:53:13 am »
Internal pump is the way to go. Why wouldn't you want to go this route?
« Reply #2 on: April 18, 2019, 07:25:17 am »
i would go with a blazer tank out of a efi that way you get the whole package at once
Offline wilrob
« Reply #3 on: April 18, 2019, 08:09:20 pm »
Mostly because I want to run an in-line A1000
« Reply #4 on: April 18, 2019, 08:37:36 pm »
wont make you go any faster
Offline wilrob
« Reply #5 on: April 19, 2019, 09:21:27 am »
Certainly not with my worn out 305, but when something else takes it's place it might...
Anyways, I asked because I am in between getting a blazer tank and using that, or getting the 20gal fuel cell from summit which has a sump so I would't need to use the stock sending unit anyways
