Author Topic: Need Advice on Replacing Floor Pans  (Read 4567 times)
Offline jfkelley
« on: May 01, 2019, 03:43:32 pm »
I have an 1976 Chevrolet K10 4x4 that the floor pan is rusted by the kickboard and along the inner rocker panel ...My question is which floor pan do I need?..Thanks
« Last Edit: May 01, 2019, 04:09:32 pm by jfkelley »
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Offline jfkelley
Re: Need Advice on Replacing Floor Pans
« Reply #1 on: May 01, 2019, 03:57:04 pm »
Offline jfkelley
« Reply #3 on: May 01, 2019, 03:59:34 pm »
Thanks I made a Newbie Mistake by not searching first ... :-[...Is there a write up I can follow since this will be my first time doing this?..Thanks In advance
« Last Edit: May 01, 2019, 04:10:28 pm by jfkelley »
« Reply #4 on: May 01, 2019, 04:10:10 pm »
Good luck with the repair and thank you for your support
Offline jfkelley
« Reply #5 on: May 03, 2019, 02:55:42 pm »
Went and Checked out the floor from under the truck and noticed I needed both Cab floor supports ordered them today as well, I think the PO never rolled up the windows in this truck by the looks of it ! ...Thanks 73-87ChevyTrucks.com Store ...!
« Last Edit: May 03, 2019, 08:12:10 pm by jfkelley »
Offline jfkelley
« Reply #6 on: May 03, 2019, 08:46:47 pm »
Since I purchased the Cab Floor pans and Floor Supports , What order should I replace the items in ?
« Last Edit: May 04, 2019, 09:08:31 pm by jfkelley »
« Reply #7 on: May 04, 2019, 01:16:15 pm »
You PM'd me but your mailbox is full. Hi, I would suggest you post this in your thread you started and add pictures. Depending on how bad it is, generally you want to graft the area out that is bad and carefully cut that section out. Once you cut the bad section out you will be able to see how the cab supports are attached. Remove or repair that section and then reinstall the floor. Are you planning on welding or using panel bond?
