Author Topic: Fuel Line Routing  (Read 9173 times)
Offline Manswame
  • '82 k10 with 305 stock
Fuel Line Routing
« on: May 03, 2019, 01:13:41 am »
Has anyone tried rerouting their fuel line from the pump to the carb on an '82 305? The routing behind the alternator is a pain in the butt and would like to know if its possible to run it elsewhere without any issues.
1982 K10 with 305 STOCK
Re: Fuel Line Routing
« Reply #1 on: May 04, 2019, 01:20:10 pm »
I think routing it that way is the best option.
Offline 75gmck25
« Reply #2 on: May 05, 2019, 06:07:23 am »
That's the simplest routing to keep it out of the way.  However, I have tall valve covers and the original routing does not leave much space to cut it and install an external fuel filter where its easy to access, but not jammed between the valve cover and air cleaner.
Bruce
Offline Stewart G Griffin
« Reply #3 on: May 07, 2019, 04:41:20 am »
One thing to keep in mind is keeping the line close to the front of the block and behind the alternator keeps it away from the exhaust manifolds or headers, which keeps the line away from HEAT.
When you say pia,  what do you mean more specifically?
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: May 08, 2019, 03:13:30 pm »
p= pain
i= in
A=derriere
1980 C-10 under construction
« Reply #5 on: May 09, 2019, 03:29:44 pm »
 ;) i know what "pia" stands for.   What i wanted to know is how, specifically, does the OP feel  running the fuel line behind the alternator in the stock way a pia?
Offline Manswame
« Reply #6 on: May 11, 2019, 12:04:11 am »
Well, probably because of the spider web of vacuum lines to be honest. I had to take off to do the fuel pump and it was a pain getting it out and back in (had to get a new one because it was kinked in a bend).
Just sucks getting it in behind everything around the coolant lines and vacuum lines...blah blah blah
Sent from my SAMSUNG-SM-G891A using Tapatalk
