Author Topic: Flashing dome light  (Read 4007 times)
Offline noclrnce
Flashing dome light
« on: May 26, 2019, 10:10:13 pm »
Ok this is weird. I have an 87 Chevy R30 crew cab. It hasn’t been started in probably a year so I put the charger on it. Got it fired up and running but I turned it off I heard a clicking sound. I thought it was the exhaust so I didn’t pay much attention. I just went outside and still heard the clicking hours later. I looked inside and the dome light is flashing. I opened the door and it stopped. I closed the door and it started flashing again. Any thoughts???
Re: Flashing dome light
« Reply #1 on: May 27, 2019, 06:13:32 am »
Morse code from the gremlins living in your truck. Decode the message
« Reply #2 on: May 27, 2019, 07:54:01 am »
Is your horn button stuck and fuse for the horn blown?
Offline noclrnce
« Reply #3 on: May 27, 2019, 08:52:17 am »
The horn has never worked since I’ve owned the truck. It has a billet steering wheel.
« Reply #4 on: May 27, 2019, 09:50:29 am »
Check your horn fuse.  Mine did something similar but my horn worked until the fuse blew.  Dome light flickered when I tried the horn and the relay was going nuts under the dash.  Not saying that is your problem but something to check
« Reply #5 on: May 27, 2019, 11:23:45 am »
Check the 4-way flasher button on the side of the column to make sure it isn't depressed.  Remove the two flashers, one at a time, to determine when the flashing ceases.
