Author Topic: TH350 Dipstick Tube Replacement....  (Read 4550 times)
Offline jfkelley
« on: June 04, 2019, 05:59:03 pm »
I have an 1976 Chevrolet K10...My transmission dipstick is leaking...I replaced the O-ring annnnndddd Still leaking ...I read in another post to replace it with an 1980 up TH350 Tube that has the grommet rubber boot..Is this correct guys ?...You all have helped me soo much with repairs on this truck...Where can I buy a new one of these ?..I checked the store and didn't see one there for sale ...Thanks in Advance !..
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Re: TH350 Dipstick Tube Replacement....
« Reply #1 on: June 04, 2019, 06:08:36 pm »
Are you sure that is where it is leaking from? Detent cable is a common leak point near the dipstick tube.
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: June 04, 2019, 06:09:35 pm »
Can't say on the dipstick,
But
what happened with the rebuild????
People tap the considerable brain trust on this site, and never let them know how it turned out...
1980 C-10 under construction
Offline jfkelley
« Reply #3 on: June 04, 2019, 06:22:11 pm »
I will check to see if it’s coming from the detent cable , it was pouring out of the dipstick until I changed the O-Ring , now it’s barely leaking ..So I just assumed it was the dipstick O-Ring
Offline jfkelley
« Reply #4 on: June 05, 2019, 08:22:05 pm »
The Transmission rebuild went well...I just finished putting new floor pans in and cab floor supports with help from a lot of the users on here how to do it ..Fixing to give it a tune up and fix that Dip Stick leak and make sure its not the Detent cable not leaking ...
Offline c10rider
« Reply #5 on: June 06, 2019, 07:22:07 am »
I had the same problem with my 74 , I switched to the gromet and stopped the leak
Offline jfkelley
« Reply #6 on: July 16, 2019, 07:37:46 pm »
Changed out the Detent cable Seal using the Top hat seal button everything up and now it seems like it leaks worse now ..With it being a 4wheel Drive I have limited space and can’t poke my head up there to see what’s leaking , going to try the mirror with forceps to see if it’s the detent cable seal again or Transmission tube ..This is getting so annoying
Offline jfkelley
« Reply #7 on: July 17, 2019, 09:00:39 pm »
So I pulled the Transmission dipstick noticed it was creased, went to O’reillys bought the chrome dipstick which I HATE!  , before installation I took some Teflon tape wrapped it around the o-ring Seal  and inserted it into the transmission filled up the transmission ran it for 30 minutes  and No leaks...Fingers Crossed no red spot in the morning
