Author Topic: 12 bolt rear end fluid capacity  (Read 14722 times)
Offline Sprinkler-Man
  • 80 GMC Sierra Classic 4x4
« on: June 07, 2019, 07:18:24 pm »
I can’t get my fill plug out but there is a breather vent on the top I can access and fill from. I have been reading to go with 2 quarts but wanted to confirm with the forum.
Re: 12 bolt rear end fluid capacity
« Reply #1 on: June 07, 2019, 08:36:58 pm »
Good luck with that. Extract the fill plug and save yourself some aggravation. Is it stripped, what's the problem?
« Reply #2 on: June 07, 2019, 08:49:25 pm »
Yes it’s striped. Unfortunately, I don’t have a welder to weld a bolt to it.  I pulled off the breather cap and can blow down through the vent, but this was with the differential cover off. Why do you see a problem?
« Reply #3 on: June 07, 2019, 10:33:39 pm »
have to get vile of one of those to confirm but one thing i know you might be able to do is put the right amount of oil in a ziplock and toss it in the differential.
« Reply #4 on: June 08, 2019, 12:22:37 am »
What??
« Reply #5 on: June 08, 2019, 03:04:17 pm »
i remember seeing on tv a few years ago someone rebuilding a read end. when they filled it they just filled a zip lock full of gear oil and tossed it in. they said the zip lock would break down and it will be ok. but i dont recall what style differential it had. so if they worked on something like a Detroit locker, i dont know if you can do the same for lets say a gov locker
« Reply #6 on: June 08, 2019, 03:44:54 pm »
I pulled the vent and put in two quarts. Took me about 15min to do. Now I can take it to a shop to get a bolt welded into the plug to get it out and replace it.
« Reply #7 on: June 09, 2019, 11:50:30 am »
What??
LMAO
Use this: http://www.ctatools.com/index.php?route=product/product&path=59&product_id=150
« Reply #8 on: June 09, 2019, 12:29:46 pm »
Why would anybody entertain, let alone recommend, using something that belongs in the county dump to put "clean oil" in a differential?  But then, if it was on TV or UBoob, it must be true....
« Reply #9 on: June 09, 2019, 03:27:37 pm »
its true lol thats kind of why i wanted one of you two to confirm what i saw. glad we got that all cleared up now, but for real i remember them tossing it into the rear then sealing it up and saying something like the gears will break it down in no time
Offline JohnnyPopper
  • Old Goof
« Reply #10 on: June 10, 2019, 09:42:18 pm »
OMG
Was it from the '70s or some other mislead era? HeeHaw?
1980 C-10 under construction
« Reply #11 on: June 13, 2019, 08:20:28 am »
it was one of those shows on power block or something like that, believe back around 2010.
  • Old Goof
« Reply #12 on: June 13, 2019, 01:11:31 pm »
Well, plastic is a byproduct of oil, so in theory it will return to 'natural state'...
« Reply #13 on: June 13, 2019, 02:24:26 pm »
that was my thinking also and why it made sense. but i wasnt sure if somehow it would mess up the clutches on some model rear ends
« Reply #14 on: June 13, 2019, 03:24:46 pm »
Give it a rest.  Nothing about it makes sense.  It is poor practice!
