Author Topic: Found me some wonky engine mounts  (Read 3282 times)
Offline Chuck Step-a-side
« on: June 09, 2019, 03:59:12 pm »
So I've pulled out the worn out center bolt 350 engine and started to move some of the old parts over to the newer 350 and I notice the engine mount to motor mount bolt holes were butchered.
If I am correct, the original engine was a 305; did this need to done in order to install the 350 engine? Should I smooth out the holes and install them as-is or locate replacement engine mounts?
Re: Found me some wonky engine mounts
« Reply #1 on: June 09, 2019, 07:05:43 pm »
Slight differences between BBC and SBC.  Is there a part # stamped on it?
« Reply #2 on: June 09, 2019, 07:11:25 pm »
Just get new clamshells
« Reply #3 on: June 09, 2019, 07:25:11 pm »
All small block in the box.
New clams sounds like a plan.
Thanks Vile-man!!
