Author Topic: Changing Spark Plugs Question  (Read 3808 times)
Offline jfkelley
« on: June 25, 2019, 08:16:44 pm »
You guys are great at providing very useful information, and I have a new question...So before I gave my son the truck I changed the spark plugs in it ...The "Kid" 2 O'reillys sold me the plugs and said to gap them @ .045 ...Is this correct gap for an 1976 Chevrolet K10 400 CID , Should I move the GAP to .035..?...it seems like its harder to start since changing the spark plugs...Any thoughts?q
« Last Edit: June 25, 2019, 08:29:01 pm by jfkelley »
1976 Chevrolet Scottsdale 4x4 ,K10 33” BF Goodrich All-Terrain .. in the middle of an LS swap LM7/4l60e/NP241C
Re: Changing Spark Plugs Question
« Reply #1 on: June 26, 2019, 05:42:25 am »
What plugs did you use?
Offline jfkelley
« Reply #2 on: June 26, 2019, 12:29:19 pm »
AC Delco Rapid Fire #10
« Reply #3 on: June 26, 2019, 03:44:31 pm »
It always struck me as odd but Rapid Fire plugs generally don't perform well.  You would be better served by using CR43TS if the old plugs were burning clean when removed.  Otherwise, use R45TS.  Both should be gapped to 0.045".  The 0.035" gap was used for GM conventional ignition engines and for TBI engines.
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: June 26, 2019, 05:47:11 pm »
Before HEI?
1980 C-10 under construction
« Reply #5 on: June 26, 2019, 07:14:23 pm »
The gap used on most HEI LD truck engines (the 3.8L V6 was an exception) was 0.045".  Pre-HEI and TBI used 0.035" gaps.
