Author Topic: Spray paint marking too easy  (Read 3931 times)
Offline Rtlane
« on: July 31, 2019, 10:55:29 am »
I test painted an old inner door panel with only canyon black satin rustoleum 2x painters mark spray paint. When I do the final permanent paint job on my actual panels, i’ll be using adhesion promotor, then the black paint, then clear.
It has been a week since i painted and the test panel is easily marked with light fingernail scratch (see photo). What is the cause or is it because I didn’t clear?
Re: Spray paint marking too easy
« Reply #1 on: July 31, 2019, 12:33:24 pm »
Clear will help however if you want it durable consider a 2K urethane.
Offline Gric
« Reply #2 on: January 16, 2021, 07:15:05 pm »
I would suggest using the rustoleum vinyl dye. Works very nice with proper prep.
« Reply #3 on: January 18, 2021, 06:43:26 am »
Use vinyl & fabric paint instead or check out SEM paints.
