Author Topic: retard timing to use regular gas?  (Read 5912 times)
Offline fiddler
  • 74 Chevy C10 Stepside
« on: September 25, 2019, 08:49:37 pm »
I have a 1974 chevy C10 stepside with a 350.  It has an edelbrock carb and intake manifold and ACCEL high voltage ignition.  I have set the timing to 6 degrees before tdc in an effort to use regular gas as the regular here in California seems to be too low in octane for this engine.  I still get a lot of pre ignition with regular gas.  What are the risks of retarding the timing to use a lower octane fuel??  Thanks for your help,
Ricky
Offline 75gmck25
Re: retard timing to use regular gas?
« Reply #1 on: September 26, 2019, 05:15:46 am »
Are you sure your timing pointer is correct?  Factory timing was probably about 4 degrees BTDC, and in most cases you can run about 12 degrees BTDC on regular without any pinging issues with a stock 350.
Bruce
« Reply #2 on: September 26, 2019, 08:24:24 am »
im with bruce. i would verify TDC is actually TDC on the timing marks before doing anything else. a low compression engine should be able to run regular gas with at least 12° timing with no issues and thats before the vacuum advance kicks in.
Offline roundhouse
« Reply #3 on: September 26, 2019, 09:36:32 pm »
I always just set the timing with a vacuum gauge or by ear
Just drive it up a hill and floor it
If it pings , retard it 2 degrees
At a time till it stops pinging and don’t worry about what the pointer or light says
Using a timing light on  My bronco says it’s at 28 degrees idling
 But it runs great so what the light says is irrelevant
Offline JohnnyPopper
  • Old Goof
« Reply #4 on: September 26, 2019, 11:03:57 pm »
I'm with roundhouse, timing lights are so unreliable I just gave up and time with a Tachometer and my ear.
Find your average highway RPM range and twist that girl till she bucks and back off till she purrs.
Jus sayin... ;)
1980 C-10 under construction
Offline FlatBlack77
« Reply #5 on: September 27, 2019, 08:39:12 am »
I'm at 12btdc with only minor mods and I run 87 all day every day. That advance in timing was like turning a horsepower knob. Night and day difference
The timing cover and pointers might be bent or not even original to that motor or balancer
Offline roundhouse
« Reply #6 on: September 27, 2019, 02:46:55 pm »
Jus sayin... ;)
For the vacuum gauge I hook a gauge to the manifold and advance the timing till you reach max vacuum and back off about 2 inches
http://automotivemileposts.com/garage/v2n8.html
Offline fiddler
« Reply #7 on: September 29, 2019, 01:51:51 am »
So I will run a sanity check on my timing light on another vehicle.  Thanks for the replies all.  Information I needed before I did something drastically wrong....
Ricky
Offline FlatBlack77
« Reply #8 on: September 29, 2019, 04:05:58 pm »
Just to make sure
You are unhooking the vacuum line from the vacuum advance and plugging it before checking the timing right?
Offline fiddler
« Reply #9 on: October 03, 2019, 05:01:24 pm »
Yes on the vacuum line.  Thanks for asking.  The digital advance knob on the timing light is easily jostled.  I may have inadvertently moved it.  I ordered a light without any fancy advance stuff.  I just want a strobe when I hit the spark at number 1!
Ricky
« Reply #10 on: October 03, 2019, 06:07:33 pm »
Your base timing setting is just a starting point and will provide you with no performance improvement if you are setting it there and leaving it. An advance timing light is the way to go.
  • Old Goof
« Reply #11 on: October 03, 2019, 07:50:10 pm »
Thanks RoundHouse!
That link is solid gold, BOOKMARKED!
« Reply #12 on: October 05, 2019, 08:09:57 am »
I do not agree with that method but beware if you are following those directions in that link. For sbc or bbc the instructions for advance or retard are reversed.
  • Old Goof
« Reply #13 on: October 06, 2019, 09:42:15 pm »
Thx for the heads up VZ  :D
