Author Topic: Carb keeps clogging up  (Read 4110 times)
Offline c10rider
« on: September 29, 2019, 05:09:07 pm »
I installed a new fuel tank and sending unit because the net was falling apart and clogging my fuel line ,but my carb keeps clogging up I blow it out through the mixture screw holes and then it runs good but then it starts clogging up again , I’ve blown it at least 40 times it the last few years but it still clogs up , I’ve even tried carb cleaner and no luck I probably get a two miles of smooth driving before it starts clogging again, any input would be appreciated
Re: Carb keeps clogging up
« Reply #1 on: September 29, 2019, 07:01:32 pm »
Stop buying gas at stop and shop. Blowing through the idle mixture screws is not going to clean the fuel bowl. Make sure you are running a good filter. What carburetor is on it?
Offline c10rider
« Reply #2 on: September 29, 2019, 07:12:13 pm »
It’s a elderbrock 1405
Offline c10rider
« Reply #3 on: September 29, 2019, 07:12:56 pm »
What type of gas should I get
« Reply #4 on: September 29, 2019, 07:14:48 pm »
Remove the air horn and clean the fuel bowl and jets. There is probably gunk in there. Check your float level and drop. make sure you have a good fuel filter.
Offline c10rider
« Reply #5 on: September 29, 2019, 08:12:42 pm »
Thank you sir
