Author Topic: 1987 Chevy No power to fuel pump  (Read 32804 times)
Offline Cb8128
« on: October 09, 2019, 03:46:54 pm »
I have a 87 Chevy 3/4 ton and the fuel pump will not turn on when turning the key. I put twelve volts to the pigtail on the fuel relay and that turns on the fuel pump so it seems to be fine. I have replaced the fuel relay, and the ignition control module on the top side of the distributor after reading some of the forums in this topic but that did not change anything. What should I look into next, I'm not super mechanical but enough to be dangerous. Would the oil pressure switch be causing this?
Re: 1987 Chevy No power to fuel pump
« Reply #1 on: October 09, 2019, 04:45:11 pm »
Did you check the ECM B fuse?
Offline Shifty
  • I bleed Bowtie red...
« Reply #3 on: October 09, 2019, 06:40:00 pm »
This has happened many times in my last 87 3+3.
98 C2500 ext cab longbed
Offline Cb8128
« Reply #4 on: October 10, 2019, 10:47:50 am »
Is the ECM B fuse in the fuse panel? I went through all the fuses in there with a tester and visually inspected them and they all tested ok. I don't know if this is related but the headlights quit working about the same time it quit.
Offline ehjorten
« Reply #5 on: October 10, 2019, 01:55:36 pm »
Can you get the fuel pump to run by jumpering the Fuel Pump Prime circuit 490?  It is a red jumper wire that comes off of the Fuel Pump Relay.  Run a fused wire from the + side of the battery to this wire.
-Erik-
Offline Cb8128
« Reply #6 on: October 10, 2019, 04:25:06 pm »
Yes I ran twelve volts to that pigtail and it would turn on the fuel pump.
Offline ehjorten
« Reply #7 on: October 11, 2019, 08:36:57 am »
That jumper wire completely bypasses your fuel pump relay, so the problem has to be between the relay and your battery.  Circuit 450 off of the relay is black w/ white and is a ground for the coil side of the relay, the part the controls the switching on and off of the power.  Make sure you have a good ground there.  Circuit 440 is Orange and provides power to the fuel pump.  It should have 12 V.  I am not sure if it is there all the time or if it is there when you turn the key on, but it comes through the ECM.  Circuit 120 is Gray and goes to the fuel pumps, so we know that one is working.  Last is Circuit 465 which is Green w/ White.  This is the control circuit coming from the ECM.  It is a signal from the ECM to turn on the fuel pump.  This should have 12 V briefly when you first turn the key on.  It should run the pumps for a few seconds.
I am sure BD can chime in if I'm telling you something wrong or if I'm not being completely accurate.
I would think that you should be able to get your truck to run if you jumper to the fuel pump prime wire and then try to start it.  Once it fires, if you remove that jumper wire and it keeps running, then the Fuel Pump Oil Pressure Switch is doing it's job and keeping the truck running in the case of a failed relay, but you did say you replaced the relay.
If you are getting power to the relay and you have a good ground to the relay, then I would think something is wrong with the control circuit from the ECM.
« Last Edit: October 11, 2019, 08:41:32 am by ehjorten »
-Erik-
« Reply #8 on: October 11, 2019, 06:53:40 pm »
from the link vile posted
even if the FPR is bad the OPS will still give the fuel pump power. the ecm B fuse is in the fuse box. once you find it make sure its getting power when the key is on.
on another note i dont see how the headlights and fuel pump are related but did you ever fix the headlight issue?
Offline ehjorten
« Reply #9 on: October 14, 2019, 08:42:09 am »
The OPS will only keep a currently running engine running.  If the FPR isn't working and the vehicle isn't currently running, you won't be able to start it.
-Erik-
« Reply #10 on: October 14, 2019, 09:44:21 am »
Not true.  With regard to 1987 GM TBI, once the engine builds >5± PSI while cranking, the OPS contacts close and supply power directly to the fuel pump, bypassing the fuel pump relay.  Assuming no other gremlins exist the engine will still start, but after many more seconds of cranking.  The OPS is just a failsafe in the event of fuel pump relay failure.  It's redundant.
« Reply #11 on: October 14, 2019, 11:22:47 am »
More to the point of the original complaint, use Chart A-3 and Chart A-5 supplemented by the explanation provided by...
I would think that you should be able to get your truck to run if you jumper to the fuel pump prime wire and then try to start it.  Once it fires, if you remove that jumper wire and it keeps running, then the Fuel Pump Oil Pressure Switch is doing its job and keeping the truck running in the case of a failed relay, but you did say you replaced the relay.
Offline Cb8128
« Reply #12 on: October 14, 2019, 12:15:59 pm »
I haven't had the chance to look at it again lately but I will use that A5 chart to try narrow my problem down. Thanks for the help
Offline Cb8128
« Reply #13 on: October 17, 2019, 10:57:24 am »
Well I finally got time to look at it and it was the ECM B fuse, my dad had went through all of them and had told me they all checked good... apparently he missed one. I replaced the fuse and the pump is kicking on now. Thanks for all the help
