Author Topic: 1977 C20 454  (Read 8813 times)
Offline cffisher
1977 C20 454
« on: October 10, 2019, 04:56:16 pm »
As above 1977 C20 454 100230 miles 400 trans 3.21 rear 265/75/R16 tires. I'm pulling a 30' 8K# fifth wheel. Problem it doesn't like hills. It seems to not have the power I'd expect on hills. It is fine on flat ground. Any suggestions? I thinking cam and intake but not sure which ones.
Retired and loving it.
Re: 1977 C20 454
« Reply #1 on: October 10, 2019, 06:39:53 pm »
I'd say you need at least 3.73:1 also is it downshifting?
Offline JohnnyPopper
  • Old Goof
Re: 1977 C20 454
« Reply #2 on: October 10, 2019, 07:02:04 pm »
I had a '73 version of that same truck, and 5th wheel.
I replaced the cam with what I remember as an 'rv' cam, and it made a huge difference!
Between 2500-3500 RPM it was like nothing was behind me.
Curious about VZ's question on downshifting.
On serious grades I would manually shift it and keep it in that RPM range.
Full Disclosure: I had a water injection system on it too, which if you know about, are very effective when under load.
However,
It's the reason why I had the opp to change out the cam.
I had it parked on a slope and it filled up #2 cylinder. "Hydolock" is a ugly thing...  :o
1980 C-10 under construction
Offline Stewart G Griffin
Re: 1977 C20 454
« Reply #3 on: October 12, 2019, 11:32:55 am »
i was looking at the stats:  i think you got 370 ft/lbs at 2800rpm.
i think my approach would be to check, and if possible, advance timing a little.
Then, i think you need at least 3.42 to 3.73 gear.  Since 3.42 is so close to  3.21, then let's go  with 3.73 to 4.11.    Then get a Gear Vendor's overdrive/underdrive unit.  It's $3000, but that's still much cheaper than a new truck.
i would also want to go with dual wheels on the rear axle with 8K, but that's just me.........
Re: 1977 C20 454
« Reply #4 on: October 12, 2019, 01:23:58 pm »
Check the specs on the gear vendor. Pretty sure they have a up/tq limit and a gcwr.
Re: 1977 C20 454
« Reply #5 on: October 13, 2019, 04:14:28 pm »
i think up to 1200hp and at least 25,000 lbs. gcwr:
https://www.gearvendors.com/commercial.html
  • Old Goof
Re: 1977 C20 454
« Reply #6 on: October 13, 2019, 05:36:54 pm »
I've got some OEM Dually fenders if you choose to go that route!
Used but in great shape. 600.00 for both, you cover shipping from 92111.
Re: 1977 C20 454
« Reply #7 on: October 13, 2019, 08:15:57 pm »
i'd love to put a one-ton/3/4 ton springs and rear axle on the truck as well as dually fenders, the west coast mirrors and cab marker lights  :)   But that's for later.......
« Last Edit: October 13, 2019, 08:17:36 pm by Stewart G Griffin »
