Author Topic: wrong engine  (Read 7549 times)
Offline setandreel
wrong engine
« on: September 22, 2006, 05:46:00 pm »
What is the diff. between a carb engine and a tbi? I have been told the heads are not the same.
Thanks
Mike
Re: wrong engine
« Reply #1 on: September 22, 2006, 09:42:00 pm »
Injected heads the four holes in the midle for the the intake are at a diferent angle than the others. Carbed heads the holes are all the same angle. You can buy an aftermarket carb intake to fit injected heads.
Offline setandreel
Re: wrong engine
« Reply #2 on: September 22, 2006, 10:13:00 pm »
Blazin
problem is engine is a carb and I have tbi. 3 years ago I had a jasper engine installed, the installer ordered a carb engine its done good till 6 months ago started surging and idleing rough took it to a shop and they could not figure it out, they unpluged the egr and it runs good. well long story short I can't change out the motor but my service engine lite comes on now showing code 32 (egr) it will stat on until I cut off the truck and will stay off for awhile maybe 100 miles then its back on won't come on on short trips 50 miles or so. can I get a chip to fool the emc? or do I have to live with the ses lite. if I hook up the egr it runs real bad and will cut off at deceleration and idles very rough
thanks
Mike
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
egr
« Reply #3 on: September 23, 2006, 12:25:00 am »
Did you try a new egr?
Offline setandreel
Re: egr
« Reply #4 on: September 23, 2006, 06:27:00 am »
yes new egr, took off egr and blew air thru the port on the manifold and air comes out the exaust.
Offline roundedline
Re: egr
« Reply #5 on: September 23, 2006, 11:54:00 am »
Check all of the vacuum lines.  While the truck is running what does the engine do when you pull up on the EGR diaphram?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline setandreel
Re: egr
« Reply #6 on: September 23, 2006, 02:20:00 pm »
Checked all the vacum lines and they are good. When you pull up on the EGR diaphram it trys to stall
Offline RSBAD454
Re: egr
« Reply #7 on: September 25, 2006, 07:57:00 am »
port design on the head will not cause the TBI engine to surge. If it did have an effect, it would have started from the get go.
Toys are my game
http://
EGR solenoid
« Reply #8 on: September 26, 2006, 09:26:00 pm »
The EGR solenoid is probably sticking. Just replace it.
