Author Topic: 4 inch lift  (Read 21637 times)
Offline BradRuiz 83
4 inch lift
« on: November 10, 2019, 08:45:39 pm »
I am going with a 4 inch lift on my k10 longbed, but not sure if I want to put 33s or 35s. Anything helps....
Offline Mario
Re: 4 inch lift
« Reply #1 on: November 10, 2019, 08:59:39 pm »
My preference would be 32s.  I think 33s will barely clear.  I'm just guessing that your rear end ratio is 3.72?  You'll be too high geared with 35s.  It'll feel like your engine is taking a while to get into it's power band.
Mario
Santa Cruz, NM
1972 C10 4x4 350 350TH NP205
1981 K20 355 NV4500 NP208 GM14SF GM10
2005 3500 Duramax Allison 5spd
Offline BradRuiz 83
Re: 4 inch lift
« Reply #2 on: November 10, 2019, 09:02:07 pm »
Thanks....
Re: 4 inch lift
« Reply #3 on: November 11, 2019, 07:06:27 am »
If you are going all spring lift, 33"s minimum otherwise it will look goofy.
Offline BradRuiz 83
Re: 4 inch lift
« Reply #4 on: November 11, 2019, 10:33:25 am »
Thanks man...
Re: 4 inch lift
« Reply #5 on: November 12, 2019, 08:10:15 am »
power band will depend on your gearing, but like vile suggested you have to go with 33s or higher. with a 4" you can fit 35s
http://forum.73-87chevytrucks.com/smforum/index.php?topic=31301.0
Offline roundhouse
Re: 4 inch lift
« Reply #6 on: November 14, 2019, 08:07:58 pm »
If you have the money , Alcan spring is the best riding spring you can buy
33s will fit with no lift on stock rally wheels
Offline SlayTank
Re: 4 inch lift
« Reply #7 on: November 17, 2019, 09:43:56 pm »
I read up on Alcan they have been going down the drain recently according to the internet. Any other recommendations for good quality lift springs? I had old man emu on my Toyota and they are awesome. To bad they don’t make springs for our trucks.
Offline Shifty
  • I bleed Bowtie red...
Re: 4 inch lift
« Reply #8 on: November 18, 2019, 09:09:20 am »
What about ORD?
98 C2500 ext cab longbed
